cbee Occasional Visitor
Posted: Tue Dec 26, 2006 3:10 pm Post subject: Tom Tom Go 300 V6.520 |
Hi and a Merry Christmas to all, I have a TTG300 and the latest version 6.520 I have done everything that I needed to do with the .ogg files and I have them all in the same place also with version 6.150 this all worked fine all the warning voices were spot on, but now with V6.520 they have all defaulted back to bells and bongs I have unchecked them and checked them again and have also pressed the reset as someone mentioned this would be worth a try, turned it off and back on again but all to no avail, so have gone back to V6.150 put the cameras back on and Liz Whittakers warning sounds and it works fine again, so is it just V6.520 blip or is it something I might be doing wrong. Any help would be much appreciated.
Thanks for your patience |
Hirvevarra Banned
Joined: May 24, 2006 Posts: 167 Location: East of East & then some.....
Posted: Tue Dec 26, 2006 3:42 pm Post subject: |
If you have the OGG files in place, why would you need Spoken Alerts in the data.chk file? The oggs replace this requirement......
You can use the Bells, Bongs, etc for other POI's as you don't need them for your camera warnings, as you have the OGG files running?
Put 6.520 back, add camera Warn when Nears, you should not be asked to add an Alert sound ( if you got the oggs method right ).
Are you sure you need Camera Alerts in data.chk now?????
If you need more, ask away.
regards |
Posted: Tue Dec 26, 2006 4:23 pm Post subject: |
Hi Thanks for the help, but am not sure I follow, am still fairly new to this but this is what I have done in V6.150 I left the BMP pictures and the pocket gps .ov2 files alone then took Liz Whittaker .ogg files and renamed them to look like this "pocketgps_uk_gatso_40.ogg" my bmp file reads pocketgps_uk_gatso_40 and the original pgps file reads pocketgps_uk_gatso_40.ov2 this is taken from V6.150 and works fine, thats what I don't understand because as soon as I upgrade to V6.520 I lose the spoken alerts and they default back to bells and bongs but I did notice that when I tap on warn when near poi then select a speed, it asks if I want to remove warning, when I answer no the next screen it shows is warn when closer than, I tap on done then it asks me to select a warning sound so something must be wrong as you said it should not ask me for this problem is I'm not sure what I'm doing wrong
Thanks again for your time |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Tue Dec 26, 2006 4:36 pm Post subject: |
Please have a read of THIS I suspect yopu might have the ogg file extensions double named which is explained in the guide - Mike |
Posted: Tue Dec 26, 2006 6:00 pm Post subject: |
Many thanks you were in deed right the file ext. were double named,but sorted now and works perfct, thanks again for all your help. :P |
Posted: Tue Dec 26, 2006 6:05 pm Post subject: |
Good guess, but you would be surprised how often this one crops up! once you have Windows Explorer corectly configured (as you now have) it won't happen again - Mike |
Andy_P Pocket GPS Moderator
Posted: Tue Dec 26, 2006 8:10 pm Post subject: |
I was right behind you Mike!
My fingers can type "Tools / Folder Options / View tab" without me looking now! ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
