jase1985 Occasional Visitor
Posted: Fri Dec 22, 2006 2:22 pm Post subject: Help I3 map/gps problems :( |
hi i got a garmin i3 unit and on the "view map mode" the map doesnt update its self, ie it doesnt show you your current location, eg if i set off at point 1, i drive 1mile down the road, the garmin will still show im at point 1, rather than where i am now, it takes ages for it to update current location.....
the bar along the top knows exactly where i am, its just the screen isnt updating the map
BUT its all fine in Navigation mode, the map moves when i move, its very strange, i rang garmin and they advised me to do a master reset i did upgrade from 2.7 to 3.2 but my friend is going to downgrade the software for me see if it helps |
zogman Frequent Visitor
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Fri Dec 22, 2006 2:33 pm Post subject: |
you'll find that going back to firmware v2.7 will solve the problem...let us know how you get on.. _________________ *************************** |
Posted: Fri Dec 22, 2006 3:05 pm Post subject: |
i dnt use my I3 very often as i rarely go out of town, but i recently had POI loaded after the 3.2 so could it be the amount of POI that is causing it too? lso when i press the 3 buttons when unit is out, will it reset back to 2.7? or do i need to do it via PC |
philai3 Lifetime Member
Joined: Oct 10, 2006 Posts: 71 Location: Manchester, UK
Posted: Fri Dec 22, 2006 3:28 pm Post subject: |
You need to do it via the PC. Download the executable from the links earlier in this forum, and run it. It will downgrade you from 3.2 to 2.7. I have done this up and down a couple of times, but have settled on 2.7. Since doing this I have much reduced numbers of lock-ups. I wouldn't say they have been totally eliminated, though, just much rarer. _________________ Garmin I3 October 2006
Garmin 1310 December 2009
(Firmware 3.2-2.7-3.4-2.7)
Renault Scenic with inbuilt Carminat Tom-Tom April 2013
Renault Clio
Mazda MX5 2010 |
Posted: Tue Dec 26, 2006 3:42 am Post subject: |
i have gone back to 2.7, its a little better, but still lags, could it be the POI |
Wildie Occasional Visitor
Posted: Wed Dec 27, 2006 3:01 pm Post subject: |
been testing this out for months now and the only thing i can see what making it happen is the signal strenght, when i get full signal in map mode it tracks fine, when it drops 1 bar then the fun begins.
just check the signal bars when it starts to lag in map mode. _________________ tom tom start 25
Waze |
