Posted: Sat Dec 23, 2006 11:51 pm Post subject: |
gdclark wrote: | I have now downloaded Firefox and have no problems with downloading. However it is not my preferred option but it works as a stop gap | I don't like FireFox in comparison to my chosen browser, but there is nothing stopping you using FF for the downloads and your usual browser for the main site, as you say its a stop gap -
BUT IT WORKS.
In fact that is what I have been doing, simply set the mozilla home page to the POI download page and leave the normal IE application alone - if you want to download POI use Mozilla, otherwise work as normal - Mike |
Ramases Occasional Visitor
Posted: Sun Dec 24, 2006 12:38 pm Post subject: |
SERIOUS PROBLEM WITH NEW POIs & GARMIN i3
I have just downloaded a set of new set of POIs and is has crashed my i3.
POI loader seemed to work fine but when trying to add a few more, the loader now can't find the unit.
Despite doing a full reset I cannot now get beyond the opening "Where To" or View Map" screen. It will not switch off unless the batteries are taken out and nothing works. Any help appreciated ..... |
Posted: Sun Dec 24, 2006 2:00 pm Post subject: Correction .... |
I can switch off without taking out the batteries but it is a VERY slow process. Any help to you experts out there? |
smspeedy Occasional Visitor
Posted: Sun Dec 24, 2006 5:31 pm Post subject: |
I had the same fault,crashed the I3 and nothing would work after installing the new POI,s.To fix it,i made a new POI file of just one POI ie no cameras or anything.I then connected the USB and the Garmin gstart installed the one file,overwriting all the old ones.I then deleted all the new POI's i had installed from the file on my PC and reloaded the ones i used to have on there(MaFt's set.)All back to normal now :D
Steve |
Posted: Sun Dec 24, 2006 5:48 pm Post subject: Have tried somehting similar but still no luck .... |
smspeedy wrote: | I had the same fault,crashed the I3 and nothing would work after installing the new POI,s.To fix it,i made a new POI file of just one POI ie no cameras or anything.I then connected the USB and the Garmin gstart installed the one file,overwriting all the old ones.I then deleted all the new POI's i had installed from the file on my PC and reloaded the ones i used to have on there(MaFt's set.)All back to normal now :D
Steve |
Hi Steve
I have been trying something smilar. Have now managed the persuade POI Loader to find the i3. However it reports a "communications error" so it won't send eben the simplest POI file to the i3. Any ideas?
Surely PGPSW should pull these POIs until this issue is resolved, otherwise there are going to be a lot of very unhappy people out there when they open their new sat navs and try to "improve" them tomorrow.
TIA
Colin. 8O |
Darren Frequent Visitor
Posted: Sun Dec 24, 2006 5:50 pm Post subject: |
With only two reported issues it's a little early to lay the blame at our POIs! However, it's Christmas Eve so you will understand that investigation will take a while but we will look into this. _________________ Darren Griffin |
Posted: Sun Dec 24, 2006 6:10 pm Post subject: |
Darren wrote: | With only two reported issues it's a little early to lay the blame at our POIs! However, it's Christmas Eve so you will understand that investigation will take a while but we will look into this. |
Thanks for the response Darren. There is certainly a problem. I've finally managed to sort my i3 using the fix suggested elsewhere. It has taken all day and was found "more by luck than judgement" - please take these down for a couple of days to save all those enthusiastic new GPS owners the trouble a few of us have had (3 now - all Garmin owners).
Merry Xmas, by the way! |
gdclark Lifetime Member
Joined: Feb 26, 2006 Posts: 23 Location: Hertfordshire
Posted: Sun Dec 24, 2006 6:34 pm Post subject: |
I am a Garmin user - I have the nuvi 660.
Touch wood, I have had no difficulties, however my unit does have quite a bit of free memory so this may not reflect the problems that the other Garmin users have had.
However I notice that the cameras and the other have the same format so the files themselves shouldn't be a problem.
I do have one question though:
Why are telephones shown twice? Once in the +44 format and the other as ordinary numbers. This only increases the size of the files and is very annoying |
lbendlin Pocket GPS Staff
Posted: Sun Dec 24, 2006 7:48 pm Post subject: |
No need to shout blue. It's xmas after all. which field do you want the phone number to be in, title or details/comments? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sun Dec 24, 2006 9:02 pm Post subject: |
Sorry - did'nt mean to shout - just wanted it to stand out from rest of post
Title would be good
One other thing my Garmin will only accept 3 columns, yet the garmin files are always four. I have to load each file into Excel and merge the last two columns together using an old add in I have.
Does anyone else have this problem?
I am not complaining - just asking if there is a solution
TIA
:D |
MikeB Frequent Visitor
Posted: Sun Dec 24, 2006 9:25 pm Post subject: |
Ramases wrote: | SERIOUS PROBLEM WITH NEW POIs & GARMIN i3
What version of POILoader are you using. I have tried it on my i3 and not had any problems. I loaded about 10,000 pois in as well as the Speed cams so getting on for 20,000 pois.
Maybe it is a particular dataset that is causing the problem. What POIs are you trying to load up?
I must admit that my POILoader may not be the latest version. I havent had any problems with it in the past so I havent always kept it up to date. _________________ Mike Barrett |
racman Lifetime Member
Posted: Sun Dec 24, 2006 9:39 pm Post subject: |
Hi all downloaded poi's and my i3 is dead.What should i do now |
Posted: Sun Dec 24, 2006 9:54 pm Post subject: |
Not happy tried reset not having any of it.Usb connection not recognised :x |
leehenty Occasional Visitor
Posted: Sun Dec 24, 2006 10:22 pm Post subject: |
Just had the same problem with my Nuvi 310D. Am using the latest Nuvi software and POI loader. After loading the New POI's along with the speed camera database, disconnect the Nuvi from my machine and then the Nuvi will not boot past the loading maps screen.
Using reset and also going back to factory settings still will not allow the Nuvi to boot past this part of the screen. The only way to keep it on that part of the screen is to put the USB cable in otherwise it turns itself off.
PC will not find the Nuvi at all and hence I cannot add a reduced set to the machine so that I can get to clearing them off. |
mike37 Lifetime Member
Joined: Mar 01, 2006 Posts: 82 Location: West Berkshire, UK
Posted: Mon Dec 25, 2006 12:17 pm Post subject: |
Thanks Lutz, Richard and the rest of the pocketgpsworld team and Merry Christmas.
Using Windows XP IE6 SP2, having earlier had problems accessing the POI file, I this morning clicked the Show Link button on step 5 of the download and this worked a treat when selecting either a single file or several files and using the Separate files per subcategory option.
I will provide you updates as I find things now on my travels.
Mike |
