kevdyas Occasional Visitor
Posted: Thu Dec 07, 2006 9:40 pm Post subject: iPaq Windows Mobile 2003 Update |
Hello
I have an Ipaq 3830 running Windows Mobile 2002 but would like to update it to Windows Mobile 2003, I have visited the HP website but the upgrade has now closed - does anyone know where I can download the update?
Thanks |
lbendlin Pocket GPS Staff
Posted: Fri Dec 08, 2006 4:37 am Post subject: |
You can still buy it on eBay _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Merlin2005 Occasional Visitor
Posted: Fri Dec 22, 2006 12:03 pm Post subject: |
The problem with the Ebay versions are they usually an illegal ROM which overwrites ands blanks the asset tag on the iPaq which stops certain software running. |
Posted: Fri Dec 22, 2006 11:36 pm Post subject: |
After loads (and I mean loads!!!) of searching, I have finally found the genuine HP upgrade for the iPaq 38xx series to WM2003 and it also allows downgrading to PPC2002. If anyone needs it please let me know and I can upload it to a file site like Yousendit or Sendthisfile.
:D
M2005 |
Posted: Sat Dec 23, 2006 11:04 pm Post subject: |
The file posted above is for iPaq 383x to 385x non-bluetooth models, here is the bluetooth enabled, genuine HP upgrade for the 387x and above:
http://download.yousendit.com/28585F6B58E26897
Your asset tag will still be intact if you use these, so that Microsoft Reader and Navman software that requires an asset tag will work properly.
These files *should* allow iPaq 38xx series PDA's to run Tomtom 6 under WM 2003, can someone please test these and report back? It may only work with 3850 or above models due to memory capacity requirements.
M2005 |
Posted: Mon Dec 25, 2006 4:08 pm Post subject: |
Has anyone tried these?
M2005 |
COLINRG Regular Visitor
Posted: Tue Jan 02, 2007 1:06 am Post subject: |
Hi Merlin,
The links above don't seem to be working anymore. I have the required files to upgrade a 3870 to WM2003 if anyone requires it.
The asset tag can be set so this is not lost during the upgrade.
Regards
CG |
Sprut Occasional Visitor
Posted: Fri Apr 27, 2007 2:44 pm Post subject: |
Merlin2005 wrote: | After loads (and I mean loads!!!) of searching, I have finally found the genuine HP upgrade for the iPaq 38xx series to WM2003 and it also allows downgrading to PPC2002. If anyone needs it please let me know and I can upload it to a file site like Yousendit or Sendthisfile. |
Please upload it. Old links not work. Thank you. |
bri-guy-ga Occasional Visitor
Posted: Wed Jun 25, 2008 7:50 pm Post subject: |
I could use a copy of the WM2003 update. I have heard that Navman does not support an Ipaq 3835 with Wm2003 is that correct? I am running Smart ST 2005 if that helps.
Thanks. |
