Pocket GPS World :: View topic - Software Upgrade & new GB Maps
swanwick3
PostPosted: Wed Dec 20, 2006 2:07 pm    Post subject: Software Upgrade & new GB Maps Reply with quote
I would appreciate help on the following:
My device is a Tomtom Go 300. The S/W version is 5.201. and I have the speed camera database (with voices) loaded from this site.
I am aware that the latest version of S/W is 6.520 and new GB maps are available. I have installed, but not used Tomtom Home on my PC.
My questions are: Is it worth installing the new software? Will this affect the operation of the speed cameras? What is the best/easiest way to do either one or both of the above?
Thanks in anticipation.
BodgerBaz
PostPosted: Wed Dec 20, 2006 2:15 pm    Post subject: Reply with quote
It's usually a good idea to upgrade to new software where it comes out as it is often brought to fix earlier errors/bugs.
Upgrading the software will install a new data.chk file so your voice warnings will revert back to the default bells and boings unless you are using OGG file voice warnings. If you arn't using the OGG files you could download the appropriate updated data.chk file so the voice warnings are re-established.
I'd be inclined to use the TomTom HOME facility to keep your GO up to date with correct versions and to allow you to make backups (which you should do before commencing ANY upgrade).
Bodger
thebinman
Banned
PostPosted: Wed Dec 20, 2006 2:53 pm    Post subject: Reply with quote
Just download the latest firmware from here:
http://myweb.tiscali.co.uk/oldboy/TomTomUpdates/index.html
swanwick3
PostPosted: Wed Dec 20, 2006 3:30 pm    Post subject: Thanks for the promt replies so far Reply with quote
Binman - I am not too experienced in this game. How do I apply the upgade after I have downloaded from the site you suggest? Will I still have to install a new data.chk file?
Thank you
thebinman
Banned
PostPosted: Wed Dec 20, 2006 4:24 pm    Post subject: Re: Thanks for the promt replies so far Reply with quote
Thank you
The instruction says "Copy the 6 Unzipped Files to the Root of the SD Card.
When the GO reboots it will do so 3 times. Just let it cycle till it has finished.
Normal switch on takes only about 4 secs!
Any time the GO is connected to the PC, expect the cyclic reboot on disconnection.
Oldboy."
PostPosted: Wed Dec 20, 2006 5:34 pm    Post subject: Reply with quote
And yes, you always need the correct numbered version of the replacement data.chk for your software version - UNLESS you switch over to using .ogg audio files (as discussed at length here), then you can leave the original TomTom supplied data.chk in place and never have to think about it again!
swanwick3
PostPosted: Wed Dec 20, 2006 8:24 pm    Post subject: Reply with quote
BodgerBaz, thebinman, Andy_P2002
Thank you all for your help. I have successfully upgraded to 6.520 and the sound alerts have been restored. Will have to check it out further but so far so good. Next step is the GB map upgrade.
Thanks again.
BodgerBaz
PostPosted: Thu Dec 21, 2006 8:49 am    Post subject: Reply with quote
I'm glad you got it working.
At some point it might pay to experiment with the OGG file spoken voices alternative (documented in great detail elsewhere). It will then mean that whenever a newer software version comes out you won't have to go through this again.
Bodger
bazzza
PostPosted: Thu Dec 21, 2006 8:03 pm    Post subject: New WE Maps Reply with quote
I have just downloaded and installed, via TT Home, the new Western Europe maps. I prepared for this by replacing the original SD card with a new 2GB Viking High Speed one, onto which I copied my original card. I then checked that it all still worked ok.
The maps downloaded and installed without a problem, but my TT doesn't seem any different. I tried to navigate to a foreign destination but all it gave me were British destinations. I tried to navigate to a point on a map but the only map it showed me was of the UK. I bet I've done (or not done) something really stupid, but can you guys help? Crying or Very sad
Bazzza
Bazzza
TTGO520 Version 9.430
Western & Central Europe Maps
Iphone 6
TT Via 135M
GO520 WiFi
kartracer
PostPosted: Thu Dec 21, 2006 8:07 pm    Post subject: Reply with quote
Bazza,
Your new map has been installed alongside the existing one rather than replacing it. Just switch maps:
Change preferences/ Switch map / select the Western Europe map.
Kam
Tim Buxton
PostPosted: Thu Dec 21, 2006 8:08 pm    Post subject: Reply with quote
Have you tried switching map?
Tim
bazzza
PostPosted: Thu Dec 21, 2006 8:17 pm    Post subject: Reply with quote
Thanks Tim and Kam. All ok now. I told you it would be something stupid. :P
Bazzza
Bazzza
Iphone 6
TT Via 135M
GO520 WiFi
22.093 (18 Sep 24)
