brianb53 Occasional Visitor
Posted: Sun Dec 17, 2006 1:38 pm Post subject: Incorrest speed warnings Garmin i2 |
I have downloaded the speed camera data base on to my i2 and it works ok, except I keep getting speed warnings i.e. 30mph in 40mph zones. Its where there is short stretches that changes from 30mph to 40mph and then back to 30mph. while I am in the 40 zone I am still getting 30mph warnings and it drives me mad as it interfers with voice instructions.
I only want the camera warnings can this be done? can the speed notifications be switched off? |
Posted: Sun Dec 17, 2006 2:29 pm Post subject: |
The i2 doesn't know the speed limit of the road you are on so these must be speed camera warnings, for cameras that are "off route". For example when approaching a 40mph dual carriage way if you are still on a 30 mph road then you will get 40mph warnings if a 40mph camera is close by even if not on the same road you are on.
When it happens what does it say at the top of the screen? |
Ash10 Pocket GPS Verifier
Posted: Sun Dec 17, 2006 3:25 pm Post subject: |
The default warning distances are massive, that's what's really causing this problem - you might want to have a look at reducing them to something more manageable. |
Posted: Sun Dec 17, 2006 3:45 pm Post subject: |
Quote: | The default warning distances are massive, that's what's really causing this problem - you might want to have a look at reducing them to something more manageable. |
As Ash10 has mentioned there is a tool avalible here (can't remember who makes it ) that can be used to adjust the warning timings.
Have a look at http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=43111 |
Posted: Sun Dec 17, 2006 11:15 pm Post subject: Incorrect speed warnings Garmin i2 |
Thanks for the info, have downloaded the camara manager utility and will try the new settings to see if it helps. will let you know if it works. |
