Ash10 Pocket GPS Verifier
![](modules/Forums/images/avatars/766726342477fdefb3500b.jpg)
Posted: Tue Dec 05, 2006 1:25 pm Post subject: |
ianandrewhay wrote: | thanks ash. I have now changed the timings, but as yet i have no reminders to update, is this normal? |
No - you should start getting the reminders pretty much straightaway.
Once Camera Manager has downloaded the database, it won't do so again until the version number changes - this is done in order to reduce bandwidth demands on PGPSW.
It sounds like it can't find the database that it did download - if you've changed the POI directory recently this could be the cause, or it might have accidently got deleted. Have a search on your hard disk for "PocketGPSWorld Speed Camera Database.zip" - it should be in the same directory that POI Loader is using - if not, copy it there.
ianandrewhay wrote: | I have previously manually downloaded a speed camera database onto the unit, do you think this is what is is detecting? |
No - Camera Manager won't know if you do anything behind its back manually.
ianandrewhay wrote: | Also do any new updates automatically replace any previous ones? |
Yes - old versions of the camera database are overwritten automatically. |
ianandrewhay Occasional Visitor
Posted: Tue Dec 05, 2006 3:49 pm Post subject: |
hey ash thanks for your continued help! I cannot find that file on my computer i must of deleted it accidentally - how do i get your camera manager to automatically download a new one? |
Posted: Tue Dec 05, 2006 4:21 pm Post subject: |
To force Camera Manager to download the database immediately, download and run this:
http://tinyurl.com/y73fjb
Some browsers (eg: Firefox) will open this as text - just select File then Save As from the menu to save it to disk... ;) |
Posted: Tue Dec 05, 2006 4:46 pm Post subject: |
Thanks ash... all working now. I think the problem started originally because i put the folders on various drives.
All i need to do now is take the unit for a test drive!!
Thanks for putting in a lot of your own personal time to help a lot of people with this software!
![Smile](modules/Forums/images/smiles/icon_smile.gif) |
tomthompson Frequent Visitor
![](modules/Forums/images/avatars/1833591624384b98188954.gif)
Joined: 26/08/2003 15:43:37 Posts: 386 Location: Southampton, UK
Posted: Sat Dec 09, 2006 6:09 pm Post subject: |
Ash....ASh....ASH..........
Did you see the new POI loader with support for wav files oooohhhh
ASH
ASH
![Rolling Eyes](modules/Forums/images/smiles/icon_rolleyes.gif) _________________ Asus Zenfone 2 twin sim, Garmin Zumo 550, 660 and pocketgps speed camera database
I keep on learning but they invent new things faster ,How do I keep up ? |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15156 Location: Bradford, West Yorkshire
Posted: Thu Dec 14, 2006 6:16 pm Post subject: |
didn't work for me... can we have a 'check now' button? i know theres an update cos i did it yesterday but it aint picking it up!!
MaFt |
Posted: Thu Dec 14, 2006 8:42 pm Post subject: |
MaFt wrote: |
didn't work for me... can we have a 'check now' button? i know theres an update cos i did it yesterday but it aint picking it up!! |
Don't forget to quit and restart Camera Manager...
I'm working on a few tweaks in this area - watch this space ;) |
Posted: Thu Dec 14, 2006 11:46 pm Post subject: |
Ash10 wrote: | Don't forget to quit and restart Camera Manager...
tried that... could the 2.40 beta be the issue? |
Posted: Fri Dec 15, 2006 5:42 pm Post subject: |
MaFt wrote: | Ash10 wrote: | Don't forget to quit and restart Camera Manager...
When you said that the update wasn't picked up, was it just that you weren't getting reminders? Or did it not even download the new database? |
Posted: Sat Dec 16, 2006 3:36 am Post subject: |
Ash10 wrote: |
both 'current version' and 'last checked' are blank... presumably from running the registry hack! but not been 'filled' since
MaFt |
larrens Occasional Visitor
Posted: Fri Dec 22, 2006 1:09 pm Post subject: Confused with speed cams |
I am a bit confused with all the speed cam utilities out there for the i3.
I used to use the one on PocketGPSworld that cost £2 a time & upload it with POI uploader together with other POI's - does this replace it or use the same database as the one I just mentioned?
Is it simply just loading it up & it will install the speed cam settings I need, & not overwrite my other custom POI's?
thanks |
Posted: Fri Dec 22, 2006 5:19 pm Post subject: |
This is designed by Ash to allow you to adjust the settings of the warnings for the database that you download from pocketgpsworld.
So that you can decide how long before a camera you get a warning and wether you also get an overspeed warning and when.
:D _________________ Asus Zenfone 2 twin sim, Garmin Zumo 550, 660 and pocketgps speed camera database
Posted: Sat Jan 06, 2007 8:14 pm Post subject: |
Major new release - 1.5.0.0 beta now available!
Camera Manager has had a major re-write over the last few weeks, and here it is:
http://tinyurl.com/nvlm4
Changes made:
A different version of the PGPSW camera database is now used, to facilitate some of the new features.
IMPORTANT - Before running this new version for the first time, you should delete the downloaded database ('PocketGPSWorld Speed Camera Database.zip') from your POI directory.
Removed Quit button. To quit Camera Manager, click on the close icon in the top-right of the settings window. Click on the 'Cancel' button or press 'Escape' to minimise the settings window as before.
Added option to add ACPO margin to the overspeed warnings. This margin is the leeway recommended by the Association of Chief Police Officers before prosececution occurs. Please note that this is just a recommendation, and some forces (notably North Wales) choose to operate a zero-tolerance policy instead. The default setting is off - use with caution!
Added option to display speed limit signs instead of camera type icons:
With camera types displayed (as before)
With speed limits displayed (new)
Added a Paypal button - incase you'd like to contribute something in recognition of the effort that's gone in Camera Manager. Blah, blah, got no job at the moment, mouths to feed, blah, blah... ;)
Tested on my i3, running v2.7 firmware and POI Loader v2.3.1
Enjoy 8) |
trevf Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_001.gif)
Posted: Mon Jan 08, 2007 2:16 pm Post subject: |
Well done again Ash. Is great as always.
Ash10 wrote: | Major new release - 1.5.0.0 beta now available!
Changes made:
Enjoy 8) |
_________________ Garmin i3
Firmware 3.4 |
Posted: Mon Jan 08, 2007 3:28 pm Post subject: |
Just gets better and better... |
