Pocket GPS World :: View topic - USA on I3
USA on I3
philai3
PostPosted: Thu Dec 14, 2006 4:03 pm    Post subject: USA on I3 Reply with quote
I'm off to the states next year, and I want to take my trusty I3 with me. I've looked around the forums for good advice on installing USA maps, but the results are sometimes incomplete or conflicting. One gem did turn up, this website
http://www.provantage.com/garmin-map-chart~110GRMM.htm
which has City Navigator maps at what seem very reasonable prices i.e. just under £80 including UK shipping. They have two DVD versions, and one on SD card. Which one do I go for? Is it easy to get the maps onto my I3? I know I need to get a new micro SD card, anything else required?
Anybody actually done this?
Garmin I3 October 2006
Garmin 1310 December 2009
(Firmware 3.2-2.7-3.4-2.7)
Renault Scenic with inbuilt Carminat Tom-Tom April 2013
Renault Clio
Mazda MX5 2010
zogman
PostPosted: Thu Dec 14, 2006 4:57 pm    Post subject: Reply with quote
the usa maps on the micro sd card will probably be the best..if you get the dvd ,you will have to buy a card to load it on and if you're not technically minded then that might be a problem...or you could consider buying an i3 over there for about $230 ish ...or get a latest version metroguide and use metrowiz to to upload the maps giving you autorouting..
philai3
PostPosted: Thu Dec 14, 2006 5:10 pm    Post subject: Reply with quote
Hi Zogman
I'm OK on the technical side with PC's generally, and I have a blank micro SD card. The USA map on the SD card is $40 more than the DVD's, which was putting me off a bit. Does using Metroguide ($73 on Provantage, about £37) and Metrowizz give you all the functionality of the City Navigator?
I'm a bit tempted by the $230 for a USA I3, thats about £117, and I would have a spare I3 then. Could I legally get a copy of my UK map onto it when I get back home without further expense?
Renault Clio
Mazda MX5 2010
zogman
PostPosted: Thu Dec 14, 2006 5:18 pm    Post subject: Reply with quote
metroguide/ metrowiz combination , i believe has a slight problem with roundabouts (hope someone can verify this) but as the usa doesn't have many roundabouts a cant see it being an issue..your uk i3 card should work in the usa i3..i have a spare uk card and have used it in other i3's so i cant see a problem ...you cannot make a duplicate of your original card, some peeps claim to have done it but you will need to do a search to find those related threads..
gilesme
PostPosted: Thu Dec 14, 2006 10:19 pm    Post subject: Reply with quote
Whilst in the states, this is pretty good value:
http://www.walmart.com/catalog/product.do?product_id=4232209
I paid a similar amount in sterling...
I3 easily swaps between cars/hire cars. No tell-tale round marks on windscreen. Lift off dash for easy programming / rerouting.
philai3
PostPosted: Fri Dec 15, 2006 12:54 am    Post subject: Reply with quote
Hi gilesme,
Yes, I've seen these on accessory websites, and I was wondering exactly what they were for. I presume it's to do with the Californian thing of not being able to stick things to your windscreen. I ususally use my I3 attached to my side window (athermic windscreen, can't be bothered keep plugging in the aerial), and I'd probably do that in the USA as well.
On the same Walmart site, check the prices of the I2 and I3 - both about the same price (duh?) and both about £122 - it seems we get the better deal over here, although they get more map info (bigger country, see). If they were £30 cheaper, it'd be well worth buying one.
Renault Clio
Mazda MX5 2010
gilesme
PostPosted: Fri Dec 15, 2006 3:56 pm    Post subject: Reply with quote
As indicated, I've got one of these.
Showed it to my teammates who also got KwikSave I3s at the same time. They've since got one each too !
Remember, WalMart tends to show NET prices, so you could have an extra 6% or so on top, depending on State Sales Tax.
philai3
PostPosted: Fri Dec 15, 2006 11:02 pm    Post subject: Reply with quote
What's the advantage over the windcreen sucker?
Renault Clio
Mazda MX5 2010
PostPosted: Fri Dec 15, 2006 11:09 pm    Post subject: Reply with quote
If you want to run the risk of being pulled by the cops use the OEM supplied mount, simply put, it is illegal to use a windscreen mounted device in parts of the USA so alternative solutions have to be found - Mike
philai3
PostPosted: Sat Dec 16, 2006 12:35 am    Post subject: Reply with quote
But it'd be OK on the side window?
Renault Clio
Mazda MX5 2010
MikeHunter
PostPosted: Sun Jul 22, 2007 8:14 pm    Post subject: Reply with quote
I've just bought the US maps on microSD card for my i3, will be arriving in the next few days. I'm a bit of a newbie, does anyone know what the procedure is for installing them? Do I simply inset the card into the i3?
tarqs
PostPosted: Thu Jul 26, 2007 11:05 am    Post subject: Reply with quote
Yes just pop it in. Test it by simulating a route
