Pocket GPS World :: View topic - Do I delete GB map after upgrade?
2ddesign
PostPosted: Sat Dec 09, 2006 5:09 pm    Post subject: Do I delete GB map after upgrade? Reply with quote
I have just updated my TT300 with the new UK & Irl map, using home software on my Macintosh computer. As this new map covers the UK do I delete the old GB map of 101mbs, or is it still in use?
I tried my TT300 after I installed the new map and after a reset it found the signal from the satellite ok. I tried an address and it went to it, no option to change to new map? as I have read in another post. Confused
2ddesign
Tim Buxton
PostPosted: Sat Dec 09, 2006 5:12 pm    Post subject: Reply with quote
What software is on your 300, also what version is your old map?
Tim
2ddesign
PostPosted: Sat Dec 09, 2006 5:50 pm    Post subject: Map upgrade Reply with quote
The "Great Britain map" is V562.0, the App 6.520 and the GPS v1.21, Boot 486. Hope this info helps, before I loaded the map, I had an update on the application software which was then installed 7mb - 8mb.
2ddesign Confused
Hemlock
PostPosted: Sat Dec 09, 2006 6:10 pm    Post subject: Re: Do I delete GB map after upgrade? Reply with quote
2ddesign wrote:
2ddesign
To change maps:
Change preferences,
Manage maps,
Switch Maps,
Select UK and IE…
Don’t forget to drag your cameras and poi’s, favourites (MapSettings .cfg over to the new Map folder too.
(This is for a TT1, but no doubt it will be similar for yours)
Smile
Tim Buxton
PostPosted: Sat Dec 09, 2006 6:33 pm    Post subject: Re: Map upgrade Reply with quote
2ddesign wrote:
2ddesign Confused
The old 562 map isn't compatible with the 6.520 software. It's possible that your new map is already being used. Tap the lower RHS of the screen, then tap on where it says 'Version' and it will tell you what map you are using.
Tim
2ddesign
PostPosted: Sat Dec 09, 2006 7:15 pm    Post subject: Reply with quote
Hi Tim
I tapped the RHS as you suggested and version 6.520 comes up, tapped on that and the Great Britain Map v562.0 comes up. I have just edited the map prefs as Hemlock suggested and selected the new map and now it is showing "UK and IE plus major roads of WE v660.1219" Smile
Do I now delete the old map v562.0 using TTHome software on my computer as I have only 5.6mb free?
Thank you both for your advice Smile
2ddesign
Tim Buxton
PostPosted: Sat Dec 09, 2006 7:22 pm    Post subject: Reply with quote
OK, it seems I have duff info. You can delete your old map directory but you might want to back it up first (the whole directory it is in).
Tim
Faust
PostPosted: Sat Dec 09, 2006 7:23 pm    Post subject: Re: Map upgrade Reply with quote
Tim Buxton wrote:
2ddesign wrote:
2ddesign Confused
Hmm! that's a very interesting statement given that I have the old 562 map and the latest 6.520 software and my GO300 works like a dream?
Hemlock
PostPosted: Sat Dec 09, 2006 7:26 pm    Post subject: Reply with quote
2ddesign wrote:
Hi Tim
2ddesign
This is purely down to your own preferences, I have kept mine, but then again I have plenty of space on my card.
If you would rather have the extra space on the card, why not remove the GB folder and store it on your hard drive, just as a precaution. Smile
Tim Buxton
PostPosted: Sat Dec 09, 2006 8:16 pm    Post subject: Re: Map upgrade Reply with quote
I'm now wondering if the information regarding map compatibility isn't confined to TTNavigator, and doesn't concern the Linux models at all.
Tim
PostPosted: Sun Dec 10, 2006 11:02 am    Post subject: Reply with quote
I've certainly used v562 maps with v6.52 software in my Go300 too.
23.052 (14 May 25)
