Pocket GPS World :: View topic - tomtom on xda, speed issues linking a bluetooth gps
GAZ_p_2001
PostPosted: Fri Dec 08, 2006 11:16 am    Post subject: tomtom on xda, speed issues linking a bluetooth gps Reply with quote
as anyone encountered problems with bluetooth gps and tomtom?
I've just bought a bluetooth gps, i can connect to tomtom with it fine, baud 9800, but when i drive off the map lags behind the where i really am on the road, making the whole thing useless.. i know my tomtom works ok because i've still got my old gps hardwired cradle so it must be a bluetooth setting i'm missing..
can anyone suggest some changes??? 8O
xda
PostPosted: Fri Dec 08, 2006 12:58 pm    Post subject: Reply with quote
If you gave a bit more information as to which XDA, Make model and same for bluetooth device and which version of TomTom you are using then people will be able to help you.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
GAZ_p_2001
PostPosted: Sat Dec 09, 2006 12:45 am    Post subject: OK MORE INFO... Reply with quote
i've got an iMate PDA2K on O2, running Windows Pocket PC.
the Bluetooth GPS is a generic one i've got off ebay.
Sensitivity To -147 dBm tracking, superior urban canyon performance
Channels 16 channels all in view tracking
Frequency L1, 1575.42 Mhz
C/A code 1.023 Mhz chip rate
GPS technology CPIT/NEMX GPS module
[/quote]
PostPosted: Sat Dec 09, 2006 9:33 am    Post subject: Reply with quote
Gaz, have you got the O2 Active interface software loaded on the device? if you have an O2 ROM loaded this is a possibility, if so remove it, this software slowes the unit down.
More probable cause of your problem, is too many POI's enabled, go to Change Preferences/ Manage POI/ Enable-Disable POI's and make sure NON are selected.
Now go to Change Preferences/ Manage POI/ Warn When Near POI and set up any POI's that you want to warn of.
This method still achieves camera warnings, but it doesn't slow the device down. I have been using an XDAIIs which is the same device appart from the colour, it works fine with TomTom - Mike
22.055 (29 May 24)
