Pocket GPS World :: View topic - What triggers the voice prompts?
Lester_Burnham
PostPosted: Mon Dec 04, 2006 3:55 pm    Post subject: Re: What triggers the voice prompts? Reply with quote
UnoHoo wrote:
I have posted another earlier topic concerning problems with my Nuvi 310 giving premature 'final' voice prompts.
In an attempt to try and understand what is causing this problem it would help if I knew just what 'triggers' the voice prompts at certain points on a route prior to a turning. Is it, for example, the mapping software - or the unit software? Can anyone assist with this query?
Kev
Howdy Kev
Clearly it's going to be a combination of the map data (probably including the type / class of road), the current location, and then the software.
Bearing in mind that firmware updates for at least the i3 have altered the timing of the voice prompts - which has probably caused roughly 50/50 agreement and disagreement in those that appear to comment on it.
I seem to recall seeing something similar mentioned about certain firmware updates to the Nuvi.
So it's definitely something that can be affected by firmware - because if you think about it, it's that that's actually doing this work.
AndyArk
PostPosted: Fri Dec 08, 2006 12:54 pm    Post subject: Reply with quote
Its definately the firmware - the current one for my C320 produces final promts too early for my liking (although this depends on where you are, I've noticed that urban final prompts are ok but rural aren't). Earlier firmware was much better. I've kept the later formware though as it added enhancements & fixes that I need. I talked to Garmin who were useless, told me the unit was probably faulty & I should return it. Complete crap as I proved the issue by changing formware versions.
__________________________
Andrew.
Garmin C320 & GPSMAP60CSx
