Pocket GPS World :: View topic - Problem loading up TTN6
Daviej
PostPosted: Thu Dec 07, 2006 2:57 pm    Post subject: Problem loading up TTN6 Reply with quote
Have just purchased new PDA and had to buy TTN6 as old TTN5 not compatible with windows mobile! PDA is Vodafone 1605 and has micro SD card, (kind of size you would just hate to drop for fear of never finding it again.) When I try to load up TTN6 to PDA I get an error messge when it gets to 71% on great britian, "an error occurred while writing to the file/storagecard2/greatbritain/cnode.dat.
Does anyone have any ideas? I have tried the usual soft reset etc and taking out card and putting back in? Could I have a duff card or is this one of those quirky things that comes with TTN6 that requires a fix?
Palm Vx (remember them)
Palm T3 TTN5
VPX Pocket PC TTN5 & Brodit Powered Mount
Vodafone 1605 TTN6 & Brodit Powered Mount (at least, I will be once I get it working!)
Border_Collie
PostPosted: Thu Dec 07, 2006 3:20 pm    Post subject: Reply with quote
There was a similar post to yours, can't find it at the moment, where the poster had the same problem, at 71% I believe. If I recall there was a batch of faulty DVD's.
If I can find the post I'll give you the link. Maybe you could have a look too. Two heads are better than one. :P
Daviej
PostPosted: Thu Dec 07, 2006 6:46 pm    Post subject: Reply with quote
I have not been able to find this. I have emailed TT so will see if it is a faulty DVD. Why don't they just work out of the box!
Palm T3 TTN5
NeilRitchie
PostPosted: Thu Dec 07, 2006 10:01 pm    Post subject: Reply with quote
I had a similar problem loading TT6 maps on to my XDAII. I moved the SD card from the XDA to a card reader. TomTom Home saw it immediately and I had no problem loading the map. Put it back in the XDA and it worked with no problems
It might be woth a try.
Post here http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=48556
Daviej
PostPosted: Fri Dec 08, 2006 5:45 pm    Post subject: Reply with quote
Seems this problem has TT foxed aswell, I have not been able to try the above solution as I do not have a a micro SD card reader! I have ordered one and will try when it arrives. In the mean time TT are also looking into this see response below and I continue to use tt5 on old device!!
Dear Mr Davies,
We currently cannot offer you an immediate suitable solution for this problem. We will send your question to our 2nd line technical department. Thank you for sending the screen dump. I will pass this onto our tech team and see what solution they have for you.
Please be patient and thank you for your query.
Kind regards,
TomTom Customer Support Team
Palm T3 TTN5
Daviej
PostPosted: Mon Dec 11, 2006 1:59 am    Post subject: Reply with quote
Over the weekend I purchased new 1GB Micro SD card and tried to load it to this, Guess what it worked, I had some problems with the application files as they had already load into my PDA from previous attempt. Once uninstalled and reloaded it works ok.
Could I of just had a duff 512mb Micro SD card, other things are loading to it OK? and there was loads of space for TTN6??
and why do these things have to be so small, it's worse than dropping your contact lense, was mini sd really to big, or even SD for that matter??
Palm T3 TTN5
22.094 (25 Sep 24)
