Pocket GPS World :: View topic - New UK Maps
New UK Maps
pnb
PostPosted: Wed Dec 06, 2006 7:34 pm    Post subject: New UK Maps Reply with quote
Having had the email offer of a reduced price upgrade of my TT5 and UK Map, I followed the instructions for using TT Home and downloaded the upgrades.
TT Home then offered to install to my Ipaq and so I selected the Map, not TT6, and the files were then slowly placed onto its Storage Card. (very slow through the Sync Cradle!)
Checked through explore that the Folder and files were on the card. I had the old UK Map folder, France and the new Folder with files of UK and IE with main roads of Europe.
Fired up TT5 and looked to select the new Map, but it wasn't listed, just France and the old UK Map ???
Any suggestions ??
Peter
Tim Buxton
PostPosted: Wed Dec 06, 2006 7:39 pm    Post subject: Reply with quote
Just to clarify, did your purchase include map and app.? Is your device compatible with TTN6? There are two options to buy; upgrade to TTN6 and new map, or TTN5-compatible new map only. The new map for TTN6 will not work with TTN5.
Tim
pnb
PostPosted: Wed Dec 06, 2006 8:48 pm    Post subject: Reply with quote
I believed I was buying the upgrade map for TT5, perhaps that is where it has gone wrong. TT Home does the checking and selection for you so it wasn't clear. It offered maps and TT6 for free
I have steered away from TT6 as it may be too much for my RX3715. I just wanted up to date maps.
Is there any way I can check?
Peter
Tim Buxton
PostPosted: Wed Dec 06, 2006 9:00 pm    Post subject: Reply with quote
If you have HOME and that's what you used to install the map, you have TTN6, too. You wouldn't get HOME or TTN6 with just the TTN5-compatible maps. Those maps install the 'old' way. Did you but from TomTom's website?
Tim
pnb
PostPosted: Wed Dec 06, 2006 10:28 pm    Post subject: Reply with quote
Yup, all done on their website which I have a login into.
Peter
Tim Buxton
PostPosted: Wed Dec 06, 2006 10:51 pm    Post subject: Reply with quote
And what device do you have?
Tim
pnb
PostPosted: Thu Dec 07, 2006 12:09 am    Post subject: Reply with quote
An Ipaq RX 3715
billconant
PostPosted: Thu Dec 07, 2006 1:23 am    Post subject: Reply with quote
I downlaoded a map of a section of the US after reading on there website that maps where compatible with ver 5 and above. I was using ver5. After it wouldn't showup in TT I called support who informed me that the map wasn't compatible with 5. Two days later I got an email saying that the map I wanted was now available from a link they provided. But like you I also got ver 6 with the download so installed it and it works fine on a Palm TX along with the new map I had downloaded.
Bill
pnb
PostPosted: Thu Dec 07, 2006 10:08 am    Post subject: Reply with quote
Thanks Bill,
I have just rung TT and they say backup and delete the old map, then I should be able to register and use the new one.
However I am just about to do a short trip to France and I want TT working.
I will postpone any changes until I am back!
Peter
yockneyboy
PostPosted: Sun Dec 10, 2006 2:18 pm    Post subject: New maps with Tomtom 5 on Mio 168 Reply with quote
I have the same sort of problem - running TomTom 5 on mio 168.
Ordered TomTom5 maps - which it said came with a free Version 6 - which I didn't download as I believe doesn't work on the Mio 168. The new map was installed to the Mio 168 via TomTom Home, no problem. But it still brings up the old GB map and if you try Prefs-change map it only shows the old new GB. Can you help, please.
aj2052
PostPosted: Mon Dec 11, 2006 2:32 am    Post subject: Reply with quote
yockneyboy said:which it said came with a free Version 6 - which I didn't download as I believe doesn't work on the Mio 168
TTN6 does work very well with Mio168 along with latest maps v660, if you have original Firmware then you will lose landscape mode, but the mio168 firmware can upgraded to win mobile 2003se which gives you back landscape mode and even better because one of the buttons can be configured to switch
ivanmx6
PostPosted: Mon Dec 11, 2006 1:53 pm    Post subject: Reply with quote
aj2052: Any idea where I can get the firmware update for the 168? I can't find any info on Mio Tech. Sad
aj2052
PostPosted: Mon Dec 11, 2006 2:16 pm    Post subject: Reply with quote
Yes from this site:http://home.scarlet.be/lataupe/
If you have problems or require copy of tutorial to perform upgrade then pm me (the site i prev posted for tutorial seems to have closed it).
the upgrade does not take long but you need to backup orig firmware first,
ivanmx6
PostPosted: Mon Dec 11, 2006 4:31 pm    Post subject: Reply with quote
For info there's a tutorial on how to upgrade the MIO168 to WinCE2003SE here: http://www.abuzant.com/2006/05/30/mio-168-firmware-update-tutorial.html
Just doing mine now. Smile
martint123
PostPosted: Mon Dec 11, 2006 4:53 pm    Post subject: Reply with quote
Has anyone managed to get the backlight to go off on a MIO168 with the newer firmware and TTN6? I use mine on battery power when out on the bike and since the upgrade the backlight stays on and the battery life is much reduced.
22.105 (30 Oct 24)
