Pocket GPS World :: View topic - TomTOM NOTvigationr
TomTOM NOTvigationr
nickruss
PostPosted: Mon Feb 02, 2004 10:49 am    Post subject: TomTOM NOTvigationr Reply with quote
I have TTN2 installed on a 2210. with Fortuna Clip on BT GPS
It used to work fine, but now it is very slooooow. Not only the screen refresh when updating the map, but route calculation.
It is ridiculous that Cardiff to Birkenhead took 1.5 hours to calculate. I was almost bloody there by the time TomTom had worked out the M5 / M6 was the best route!
Anyone got any ideas how to speed things up?
Nick
Talkingbollox
PostPosted: Mon Feb 02, 2004 1:34 pm    Post subject: Reply with quote
Sounds like memory card access issue.
What type of memory card are you using?
I would try defragging the card and see if it makes a difference. If not I would try it with the maps on the other type of flash card as you have a choice on the 2210.
PostPosted: Mon Feb 02, 2004 5:09 pm    Post subject: Reply with quote
This sounds like a problem with your memory card. Simple to confirm, remove card and install a small 16mb map to main memory. Test and if issues are no longer present then your memory card has a problem.
If it is the card, Softwinter's Storage Tools utility is the first place to start with a defrag. get it here.
nickruss
PostPosted: Mon Feb 02, 2004 5:27 pm    Post subject: Reply with quote
Hmm, dont think so since I tried a 2,2GB Transcend CF and 1GB Microdrive - same problem with both,.,.
PostPosted: Mon Feb 02, 2004 5:48 pm    Post subject: Reply with quote
I still think its a memory card issue. Try my suggestions and see?
a4ace
PostPosted: Tue Feb 03, 2004 3:00 pm    Post subject: Reply with quote
i had problems when i installed the software on an SD card. make sure it's installed in main memory. even voice commands have to go to main memory.
the maps can go to SD or CF card.
a4ace
PostPosted: Tue Feb 03, 2004 3:05 pm    Post subject: Reply with quote
you might have also set route calculation to 'strict.'
nickruss
PostPosted: Thu Feb 05, 2004 3:32 pm    Post subject: Reply with quote
OK, I tried the disk tools and found no errors. Formatted the CF (2.2GB Trancend) and reinstalled the GB map - still too slow to use.
I then purchased a Lexar 128MB card and installed the GB map on this - PROBLEM SOLVED - TTN2 works fine now.
One thing though - I also had the same problem with a 1GB Microdrive. Could there be an issue with maps on very large storage media? Or am I just unlucky with two faulty cards?!
a4ace
PostPosted: Thu Feb 05, 2004 3:41 pm    Post subject: Reply with quote
i had no problems on a 1Gb PQI CF card
