TrevH Occasional Visitor
Joined: Apr 02, 2006 Posts: 4 Location: Nottinghamshire
Posted: Tue Nov 21, 2006 12:14 am Post subject: Safety Camera map overlay |
where can I get the overlay map for my Streetpilot 2610 please 8O |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Tue Nov 21, 2006 1:20 am Post subject: Re: Safety Camera map overlay |
TrevH wrote: | where can I get the overlay map for my Streetpilot 2610 please 8O |
If you haven't already done so, pay your £2 (1 month) or £19 (1 year) to become a subscriber.
Follow this link:
http://www.pocketgpsworld.com/modules.php?name=Cameras
Select "Garmin" from the "SatNav System" drop down menu.
Select "UK - GPSR map overlay (Older GPS systems)" from the "Camera selections" drop down menu then click download.
The instructions and the installer are inside the zip file (get WinZip if you need something to unzip it with).
Good luck! _________________ Gone fishing! |
Posted: Sat Nov 25, 2006 11:41 pm Post subject: |
Thanx, did it, done it, just need to try it out. |
missing_user
Posted: Tue Dec 05, 2006 11:40 am Post subject: |
The database download page is still giving this misleading detail.
I had been waiting for the update and today found the update was available.
The Garmin GPSR database has not been updated yet |
missing_user
Posted: Thu Dec 14, 2006 2:56 pm Post subject: |
Has this database been updated yet?
It appears to have been, but I have failed to get it to instal!
Quote: | The Garmin GPSR database has not been updated yet |
WiRED Regular Visitor
Joined: Apr 01, 2005 Posts: 125 Location: Berkshire, UK
Posted: Thu Dec 14, 2006 6:23 pm Post subject: |
I just downloaded the overlay, and it's definitely not what I sent them 24 hours ago. I guess it just hasn't found its way into the download system yet.
/WiRED |
missing_user
Posted: Thu Dec 14, 2006 7:05 pm Post subject: |
The only choices I was given were 'Remove' or Repair'!!! |
Posted: Thu Dec 14, 2006 7:15 pm Post subject: |
strumble wrote: | The only choices I was given were 'Remove' or Repair'!!! |
Yes, that's what happens when you try to re-install the same version twice. What you've downloaded is what you already have from last time.
/WiRED |
missing_user
Posted: Thu Dec 14, 2006 8:04 pm Post subject: |
Yet the download says:-
Quote: | PocketGPSWorld.com Speed Camera Database
Version 4.123
13 December 2006 |
Darren Frequent Visitor
Posted: Thu Dec 14, 2006 8:12 pm Post subject: |
Clearly there is an issue, we'll investigate and report back _________________ Darren Griffin |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15154 Location: Bradford, West Yorkshire
Posted: Thu Dec 14, 2006 11:05 pm Post subject: |
i've only just uploaded it at about 9.30pm...
hence before that time it said 'not been updated yet' and now it says 'has now been updated'
MaFt |
Posted: Fri Dec 15, 2006 10:41 am Post subject: |
MaFt wrote: | i've only just uploaded it at about 9.30pm... |
I knew there'd be a simple answer
To make the job of knowing what version you have just downloaded a little easier, I've worked out a way of putting the Version number in the .msi file. Starting from the next download, you should be able to hover your mouse over the .msi file (once you've extracted it from the .zip) and the version number will be displayed. Alternatively you can right-click on the file and check Properties, where it will be one of the fields.
/WiRED |
missing_user
Posted: Fri Dec 15, 2006 10:53 am Post subject: |
[Friday 09:45]
It is still saying on the camera download page[with Google Map]:-
Posted: Fri Dec 15, 2006 1:10 pm Post subject: |
Firstly, can I just gratuitously point out that this is my 100'th post 8)
Secondly,
strumble wrote: | [Friday 09:45]
True, but at least the map itself has been updated.
Thirldy, MaFt, is there any way that this can be automated so that when the map updates, the message on the download screen changes? Is there anything I can do which might help such as enclosing the version number in a text file for example?
/WiRED |
Posted: Sat Dec 16, 2006 3:50 am Post subject: |
i forgot to change that reference to the GPSR overlay... i did remember the other 2 though!!
wired, the 'hover over the msi file' would be the best way for people to see the release version
MaFt |
