Yafeu Occasional Visitor
Posted: Fri Dec 01, 2006 1:48 am Post subject: MioMap 3.2 on a US c710 |
ok well im attempting to install this to my c710 atm and i can get the setup to run and installation screen up.. however it tells me installation aborted, license is not found.. anyone know where the license file is located? i have one that came with my downloaded miomap 3.2 but its in the same folder as the setup.exe and still wont find it. |
lbendlin Pocket GPS Staff
Posted: Fri Dec 01, 2006 3:33 am Post subject: |
Does the C710 still have the original Europe maps or is it one that you bought here?
On my C710 the upgrade to MioMap 3.2 went through without problem. But it is a European version, with the US maps on a separate licenced SD card _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Fri Dec 01, 2006 4:22 am Post subject: |
i bought it here in the states from newegg.com
the 3.2 software i downloaded has all the european and us maps. and license.db files
do u think the setup needs to be run from a SD card in order for it to install then? its got the autorun.exe and everything included.. just that when i run setup.exe from my gps it says license cannot be found |
Posted: Fri Dec 01, 2006 4:24 am Post subject: |
i also forgot to mention i did get the miomap updater to run ONE TIME and it told me there were updates available and said i could download 3.2
well i attempted too and of course it failed.. windows CE even gave me an error on the c710 saying 'map loader' i believe was the window title and just said error.
and now it wont run again on my pc, just says to install the usb drivers before attaching the device etc.. really annoying. |
Sallyann Lifetime Member
Posted: Fri Dec 01, 2006 10:38 am Post subject: |
Yafeu wrote: |
Is this an unlicensed warez copy? If so you may not get too much help here. |
Posted: Sun Dec 03, 2006 6:21 am Post subject: |
its a copy of 3.2 on SD with US maps.. i got it to run on my c710 successfully but it displays upside down. only a minor annoyance until im able to figure it out hopefully..
otherwise all the features and everything are working perfectly.
when i called miotech support the guy told me 3.2 would not run on c710 period. |
