Pocket GPS World :: View topic - MioMap Updater problems :(
Yafeu
PostPosted: Thu Nov 30, 2006 6:21 am    Post subject: MioMap Updater problems :( Reply with quote
Cant seem to get miomap updater to work for me, im a new c710 US version owner and want to upgrade to 3.2
when i run the updater i get a error message saying 'cannot connect to your device. Install mio usb driver and connect your device before start updater'
I have downloaded the usb driver from their website but dont know how to install it manually.. but ive also installed mio sync, mio transfer etc and those seem to work fine as well as active sync..
anyone able to help me with this?
-Chris
klystron_generator
PostPosted: Thu Nov 30, 2006 9:25 am    Post subject: Reply with quote
have you tried speaking to adam2670 in his tread
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=49269
his C710 has a different system installed and he'd love to install MioMap
i'm sure that if you have MioMap software for a C710 in the US he'd love to know
GPSBear
PostPosted: Thu Nov 30, 2006 11:19 am    Post subject: Re: MioMap Updater problems :( Reply with quote
-Chris
YYGT
Yes you get that :-) Solution seems to be the usual Windows one of rebooting reinstalling resetting rewhatever until it gets the message and works. It will most likely fail again *after* it has worked. :-(
Mio C710 on MioMap 3.3
klystron_generator
PostPosted: Thu Nov 30, 2006 5:11 pm    Post subject: Reply with quote
thanks for your additional input GPSBear
i haven't repeated the update process often enough to be confident in giving proper technical help like you
also i'd noticed that there was 1 US user desperately trying to find out about a US version of v3.2 and then another US user popped up with an installation problem so i tried at least to make them aware of each other
Sallyann
PostPosted: Thu Nov 30, 2006 6:04 pm    Post subject: Re: MioMap Updater problems :( Reply with quote
-Chris
As I understand it, the US C710 uses Destinator software, so it's unlikely that an 'upgrade' to Miomap 3.2 will work. Apart from the legal issue of using an unlicensed copy of Miomap, I would be surprised if it wasn't protected in some way. Also the maps will be different. However you may be able to buy iGo software on an SD card, and run that in the Mio instead. iGo is almost identical to Miomap. Check it out carefully before buying though!
Sal
Yafeu
PostPosted: Thu Nov 30, 2006 11:07 pm    Post subject: Reply with quote
ive downloaded a copy of miomap 3.2(igo im assuming) with US maps and license keys etc but not sure how to install it even if i were to put it on an SD card. wouldnt i need to hack my c710 and run it from the 'desktop' of windows CE?
Yafeu
PostPosted: Thu Nov 30, 2006 11:11 pm    Post subject: Reply with quote
also maybe someone can translate this for us..
-=By ReeJ=---=Kant en Klare versie=---=9-11-2006=-
1-Pak het MioMap_v3.2_pda_91maps.rar bestand uit.
2-Verwijder eventuele maps die je niet nodig hebt b.v. \MioMap\maps\Italy.fbl etc. etc. dit als je b.v. geen 1 GB SD kaart hebt, maar een 512 MB of minder.
3-Kopieer de rest naar een SD kaart.
4-Installeer MioMap 3.2 of door de PDA uit en aan te zetten (autorun) of door setup.exe dubbel te klikken.
5-Volg de instructies op het scherm.
6-Starten met die MioMap!
-De License file voor de huidige mappen staat in de directory ' MioMap ' en is direct actief. (license.db)
-In de map ' Extra Maps ' zitten extra landen en licentie files.(deze mag je ook wissen als je ze niet nodig vind)
Kaartenversies:
-MioMaps v3.2 - 91 maps incl. 2 key's license.db (\MioMap\Extra Maps\LicensFils)-
Albania.fbl 2006.1 (Use License Europe Key2)
Andorra.fbl 2006.1 (Use License Europe Key1)
Austria.fbl 2006.1 (Use License Europe Key1)
Basemap.fbl 2006.1 (Use License Europe Key1)
Belgium.fbl 2006.1 (Use License Europe Key1)
BosniaHrz.fbl 2006.1 (Use License Europe Key1)
Bulgaria.fbl 2006.4 (Use License Europe Key2)
Croatia.fbl 2006.5 (Use License Europe Key1)
CzechRep.fbl 2006.1 (Use License Europe Key1)
Denmark.fbl 2006.1 (Use License Europe Key1)
Finland.fbl 2006.1 (Use License Europe Key1)
France.fbl 2006.1 (Use License Europe Key1)
Germany.fbl 2006.1 (Use License Europe Key1)
GreatBritain.fbl 2006.1 (Use License Europe Key1)
Greece.fbl 2006.4 (Use License Europe Key1)
Hungary.fbl 2006.6 (Use License Europe Key1)
Ireland.fbl 2006.1 (Use License Europe Key1)
Israel.fbl 2006.1 (Use License Europe Key1)
Italy.fbl 2006.1 (Use License Europe Key1)
Luxembourg.fbl 2006.1 (Use License Europe Key1)
Macedonia.fbl 2006.4 (Use License Europe Key2)
Netherlands.fbl 2006.1 (Use License Europe Key1)
Norway.fbl 2006.1 (Use License Europe Key1)
Poland.fbl 2006.1 (Use License Europe Key1)
Portugalia.fbl 2006.1 (Use License Europe Key1)
Romania.fbl 2006.6 (Use License Europe Key1)
SanMarino.fbl 2006.1 (Use License Europe Key1)
Serbia_Montgro.fbl 2006.4 (Use License Europe Key2)
Slovakia.fbl 2006.1 (Use License Europe Key1)
Slovenia.fbl 2006.1 (Use License Europe Key1)
Spain.fbl 2006.1 (Use License Europe Key1)
Sweden.fbl 2006.1 (Use License Europe Key1)
Switzerland.fbl 2006.1 (Use License Europe Key1)
Turkey 2006.4 (Use License Europe Key1)
54 USA Maps 2005.2 (Use License Europe Key1)
Canada Map 2005.2 (Use License Europe Key1)
Russia Map 2005.2 (Use License Europe Key1)
WestEUMajor.fbl 2006.1 (Use License Europe Key1)
-=By ReeJ=--=9-11-2006=--
