Pocket GPS World :: View topic - i3 USB drivers won't install on Win XP SP2
Goto page Previous  1, 2
shadowritten
PostPosted: Mon Nov 21, 2005 12:03 pm    Post subject: Reply with quote
MELennium wrote:
I haven't tried to download and install the POI loader yet. Does this have a bearing on the USB driver installation?
Yes it should make a differerence as i believe this installs the driver and then your i3 will be found.
Well, I installed POI loader - which also put g Start on my PC - but still no joy! The Found New Hardware wizard still initiates, and still can't track down the drivers. I'll wait for a response from Garmin.
Thanks again to everyone.
PostPosted: Mon Nov 21, 2005 1:52 pm    Post subject: Reply with quote
after you have downloaded teh "USBDrivers_21.exe" and double-clicked it to run, do you get the install-shield wizard or not?
MELennium
PostPosted: Mon Nov 21, 2005 8:09 pm    Post subject: Reply with quote
shadowritten
Have you xp service pack 2 installed?
If not then install it & then this should find your driver.
MELennium
PostPosted: Mon Nov 21, 2005 11:57 pm    Post subject: Reply with quote
Sorry shadowritten
Did not see title oops
tiggr
PostPosted: Wed Nov 22, 2006 9:46 pm    Post subject: Reply with quote
I'm having exactly the same problem [I actually posted before I found this], running XP SP2 as well. I have also gone through everything shadowritten describes. Unless I too am missing something obvious, this also has me foxed.
Jamas
PostPosted: Sat Nov 25, 2006 12:48 am    Post subject: Reply with quote
Idea Try to connect your i3 to another USB plug preferably one without USB Hub (if any).
Jamas
SP i3 S/W 2.9-> 2.7 City Navigator V8 NT+
mnp
PostPosted: Sat Feb 17, 2007 3:45 pm    Post subject: Connecting StreetPilot i3 to Windows XP SP2 Reply with quote
I have found the solution to the problem, and it only took about 10-20 minutes....
1. Download and run the i3 USB drivers.
2. When PC detects USB device, tell it that you'll specify a location to search.
3. Browse to C:\Garmin\USB Drivers and click OK.
4. Windows will detect the relevant driver in that folder and install. Once this has been done, you'll be able to use the autoupdater.
Page 2 of 2
22.063 (19 Jun 24)
