Pocket GPS World :: View topic - ACER N35, no signal - please help!!
davemk
PostPosted: Fri Nov 24, 2006 2:47 pm    Post subject: ACER N35, no signal - please help!! Reply with quote
Thanks for reading this!
I was using the sat nav yesterday and all was fine. Went in to see a customer, came out and switched the PDA on, but Destinator3 can't find a single satellite.
So far, I've performed a soft reset, a hard reset, changed the sd card, re-installed Desintator, tried it in various places where I can usually get signal but all of these have failed.
The GPS configuration "Found GPS" but I don't get any satellites!
For what it's worth, the blue GPS LED is flashing with the antenna flipped up.
Does anyone have any suggestions please?? Really grateful for any advice. Thanks.
Dave.
Border_Collie
PostPosted: Fri Nov 24, 2006 4:54 pm    Post subject: Reply with quote
Strange going on it appears.
Yesterday both my friends Mio 168 and my Mio P350 both refused to lock on, even when we tried using our external aerials outside under an unobstructed sky. Mine's OK today, although only locking on 7 out of the 12 in view, I haven't spoken to him today about his.
I wonder how many more people had the same problem.
'The end of the World may be nigh'. :P
davemk
PostPosted: Fri Nov 24, 2006 5:12 pm    Post subject: Reply with quote
I was hoping it was atmospheric conditions yesterday.... alas, it's still not working. It's currently sitting on the window sill trying to catch the attention of any passing satellites!
Border_Collie
PostPosted: Fri Nov 24, 2006 6:15 pm    Post subject: Reply with quote
This is a freebie you can use WinCE Navigator CLICK HERE to see which NMEA $trings are being received.
When first using Winfast tap on Tools - Port Setting and select Protocol, which should be NMEA then the Port and Baud Rate 4800. (Although you can set the Baud to 57600 and after clicking OK tap on the 2nd Icon at the bottom, two chasing arrows, and it will select the correct Baud rate).
To save a file using Winfast you have to tap on the 'floppy icon' and name the file and select where to save to. You can then transfer the file to your Desktop to open in Notepad or similar.
When you've finished with Winfast you MUST go to Tools - Disconnect then Tools - Exit. Don't use the 'X' top right or it will not release the port.
To give you an idea of the results you can get. At least you will be able to see what is, or is not, happening with your device.
All data is received every second except GSV, which is every 5 seconds. There are three GSV lines 3.1, 3.2 and 3.3. This represents Line 1 of 3, 2 of 3, 3 of 3.
$GPGGA,150904.000,5122.2861,N,00035.9727,E,1,06,1.3,44.3,M,47.0,M,,0000*65
$GPGLL,5122.2861,N,00035.9727,E,150904.000,A*39
$GPGSA,A,3,06,25,30,01,14,02,,,,,,,2.4,1.3,2.0*30
$GPRMC,150904.000,A,5122.2861,N,00035.9727,E,0.19,35.99,250906,,*38
$GPVTG,35.99,T,,M,0.19,N,0.4,K*5A
$GPZDA,150905.000,25,09,2006,,*54
$GPGGA,150905.000,5122.2860,N,00035.9725,E,1,06,1.3,44.5,M,47.0,M,,0000*61
$GPGLL,5122.2860,N,00035.9725,E,150905.000,A*3B
$GPRMC,150905.000,A,5122.2860,N,00035.9725,E,0.22,324.13,250906,,*03
$GPVTG,324.13,T,,M,0.22,N,0.4,K*63
$GPZDA,150906.000,25,09,2006,,*57
$GPGGA,150906.000,5122.2860,N,00035.9725,E,1,06,1.3,44.8,M,47.0,M,,0000*6F
$GPGLL,5122.2860,N,00035.9725,E,150906.000,A*38
$GPRMC,150906.000,A,5122.2860,N,00035.9725,E,0.26,129.08,250906,,*01
$GPVTG,129.08,T,,M,0.26,N,0.5,K*63
$GPZDA,150907.000,25,09,2006,,*56
$GPGGA,150907.000,5122.2858,N,00035.9725,E,1,06,1.3,45.0,M,47.0,M,,0000*6C
$GPGLL,5122.2858,N,00035.9725,E,150907.000,A*32
$GPRMC,150907.000,A,5122.2858,N,00035.9725,E,0.36,143.66,250906,,*0E
$GPVTG,143.66,T,,M,0.36,N,0.7,K*64
$GPZDA,150908.000,25,09,2006,,*59
$GPGGA,150908.000,5122.2857,N,00035.9725,E,1,06,1.3,44.9,M,47.0,M,,0000*64
$GPGLL,5122.2857,N,00035.9725,E,150908.000,A*32
$GPGSV,3,1,11,30,75,081,40,06,63,201,39,24,56,245,,25,38,303,23*76
$GPGSV,3,2,11,05,34,095,,01,33,277,33,02,27,056,26,14,21,226,24*73
$GPGSV,3,3,11,04,05,024,18,31,05,338,,07,01,227,09*40
$GPRMC,150908.000,A,5122.2857,N,00035.9725,E,0.17,330.05,250906,,*0E
$GPVTG,330.05,T,,M,0.17,N,0.3,K*60
$GPZDA,150909.000,25,09,2
And the following I found very helpful.
Decode of selected position sentences
The most important NMEA sentences include the GGA which provides the current Fix data, the RMC which provides the minimum gps sentences information, and the GSA which provides the Satellite status data.
GGA - essential fix data which provide 3D location and accuracy data.
$GPGGA,123519,4807.038,N,01131.000,E,1,08,0.9,545.4,M,46.9,M,,*47
Where:
GGA Global Positioning System Fix Data
123519 Fix taken at 12:35:19 UTC
4807.038,N Latitude 48 deg 07.038' N
01131.000,E Longitude 11 deg 31.000' E
1 Fix quality: 0 = invalid
1 = GPS fix (SPS)
2 = DGPS fix
3 = PPS fix
4 = Real Time Kinematic
5 = Float RTK
6 = estimated (dead reckoning) (2.3 feature)
7 = Manual input mode
8 = Simulation mode
08 Number of satellites being tracked
0.9 Horizontal dilution of position
545.4,M Altitude, Meters, above mean sea level
46.9,M Height of geoid (mean sea level) above WGS84 ellipsoid
(empty field) time in seconds since last DGPS update
(empty field) DGPS station ID number
*47 the checksum data, always begins with *
GSA - Satellite status
$GPGSA,A,3,04,05,,09,12,,,24,,,,,2.5,1.3,2.1*39
Where:
GSA Satellite status
A Auto selection of 2D or 3D fix (M = manual)
3 3D fix - values include: 1 = no fix
2 = 2D fix
3 = 3D fix
04,05... PRNs of satellites used for fix (space for 12)
2.5 PDOP (dilution of precision)
1.3 Horizontal dilution of precision (HDOP)
2.1 Vertical dilution of precision (VDOP)
*39 the checksum data, always begins with *
GSV - Satellites in View .
$GPGSV,2,1,08,01,40,083,46,02,17,308,41,12,07,344,39,14,22,228,45*75
Where:
GSV Satellites in view
2 Number of sentences for full data
1 sentence 1 of 2
08 Number of satellites in view
01 Satellite PRN number
40 Elevation, degrees
083 Azimuth, degrees
46 SNR - higher is better
for up to 4 satellites per sentence
*75 the checksum data, always begins with *
RMC - NMEA has its own version of essential gps pvt (position, velocity, time) data. It is called RMC,
The Recommended Minimum, which will look similar to:
$GPRMC,123519,A,4807.038,N,01131.000,E,022.4,084.4,230394,003.1,W*6A
Where:
RMC Recommended Minimum sentence C
A Status A=active or V=Void.
022.4 Speed over the ground in knots
084.4 Track angle in degrees True
230394 Date - 23rd of March 1994
003.1,W Magnetic Variation
*6A The checksum data, always begins with *
GLL - Geographic Latitude and Longitude is a holdover from Loran data and some old units may not send the time and data active information if they are emulating Loran data. If a gps is emulating Loran data they may use the LC Loran prefix instead of GP.
$GPGLL,4916.45,N,12311.12,W,225444,A,*31
Where:
GLL Geographic position, Latitude and Longitude
4916.46,N Latitude 49 deg. 16.45 min. North
12311.12,W Longitude 123 deg. 11.12 min. West
225444 Fix taken at 22:54:44 UTC
A Data Active or V (void)
*31 checksum data
VTG - Velocity made good. The gps receiver may use the LC prefix instead of GP if it is emulating
Loran output.
$GPVTG,054.7,T,034.4,M,005.5,N,010.2,K
where:
VTG Track made good and ground speed
054.7,T True track made good
034.4,M Magnetic track made good
005.5,N Ground speed, knots
010.2,K Ground speed, Kilometers per hour
Note that, as of the 2.3 release of NMEA, there is a new field in the VTG sentence at the end just prior
to the checksum. For more information on this field see here.
Receivers that don't have a magnetic deviation (variation) table built in will null out the Magnetic track
made good.
MSS - Beacon Receiver Status
$GPMSS,55,27,318.0,100,*66
where:
55 signal strength in dB
27 signal to noise ratio in dB
318.0 Beacon Frequency in KHz
100 Beacon bitrate in bps
*66 checksum
davemk
PostPosted: Fri Nov 24, 2006 8:37 pm    Post subject: Reply with quote
Thanks for the info Lost Property. I'll have a go with the program you suggested although I think I might end up coming back for more advice as I'm not very technically minded!
I'll report back when I've done it.
davemk
PostPosted: Fri Nov 24, 2006 9:59 pm    Post subject: Reply with quote
Lost Property - I'm assuming that I need to download two seperate files from that site? The first being WinCE Navigator under "Utilities", the second being WinFast Navigator under "Driver & Application". For some reason, it won't let me download Winfast, which I'm guessing I need?!
I used the GPS Monitor but don't know how to save it - there wasn't an option to save the results as you described. I can't even find the "Help" menu that should have been downloaded.
I've looked at the "Single Level" view, which has plenty of red circles - do these represent the satellites?
If you could offer further help, I'd be grateful! Like I said, I'm a bit of a novice at this type of thing!
Thanks.
Border_Collie
PostPosted: Fri Nov 24, 2006 11:04 pm    Post subject: Reply with quote
You only need the one file Utility CE which includes instructions in PDF form.
Yes, they Start off RED, then BLUE and finally GREEN when locked.
SV = Satellite Number, St is associated with SiRf (ignore this), Az = Azimuth - El = Elevation and SV = Signal Strength.
To get a BLUE you need numbers in the teens and GREEN usually over 21 and normally well into the 30's and 40's+
On the bottom line you have Tools - View and 5 Icons.
The first one, which connects or disconnects Winfast is, if you look carefully, a male/female plug being connected (took me ages to work out what it represented Smile )
Icon 2, chasing arrows, is the one I mentioned earlier, used to find Baud rate.
Icon 3, a double bar, this pauses the data being shown in View - Development.
Icon 4, a brush, sweeps the data in View development,
Icon 4, a floppy disk is the one used to Save NMEA data.
Make sure Winfast isn't running and tap on View - Development.
If there is any data shown use the brush icon to clear the screen.
Tap on the Floppy Icon and enter something like First Test, in the Name box.
Choose a folder, on your Pocket_PC, where you would like to save the file.
Choose the location.
You could use Folder None and Save to Storage Card, this will make it easier for you to find. You can then open the text file to view the results.
Tap on Save then on the Connect icon.
Let it run for about 30 seconds and tap the Floppy icon again. The results will now be saved.
Open the file in something like Notepad and copy and paste the first 30 or 40 lines here and I'll see if I can spot your problem.
davemk
PostPosted: Sat Nov 25, 2006 3:03 pm    Post subject: Reply with quote
It was CE that I downloaded, from the Europe site but I didn't get any instructions in the Zip file.
The screen's a little different to how you describe too - it's as you describe apart from the brush is now a bin icon, and the save icon isn't there.
Thanks for the instructions. I made sense of your 1st set of instructions after reading it a few times (the penny was a bit slow to drop!!). I was getting a screen of info, similar to the one you posted but the satellites weren't locking although they were being detected (they remained red) so I assumed that this meant that the reciever wasnt at fault (?).
I kept on with it all night and eventually found 1 satellite. Tried an hour or so later and it found 2, then 3 a little later on. I've tried it a few times this morning and it's registering 11 from within the house with a strong signal.
I've just re-checked it and it's still working so the problem seems to have been resolved.
Really grateful for the comprehensive advice - much appreciated.
It's also worth pointing out that I'd reported the problem to Acer, even though the product is 14 months old. Great service from them, they even agreed to repair it under warranty. Excellent customer service.
Border_Collie
PostPosted: Sat Nov 25, 2006 6:32 pm    Post subject: Reply with quote
Glad you got it running OK.
Make sure you unzip the folder and Install from the newly created folder, you'll then get the Instructions.
The Winfast version you are using, without the Floppy Save Icon, is v1.1.
If you go back to http://www.leadtek.nl/nts/uk/index.php?pageid=2&dl_id=146 and download the Utility - CE, which shows as v1.1 but is actually 1.3, you will be able to save the NMEA sentences to view at a different time. E.g. Start Winfast CE on it's own, and set it to save, then go for a drive. On your return tap on the Floppy icon again and then transfer the saved file to Notepad. You'll be able to look down the list and you'll be able to see how sats are found or lost, your speed at various points, height etc. It takes a little getting used to but if you add a space above the GGA sentence, you will be able to read off each 5 second section quite easily.
Common Sentence Descriptions
$GPGGA Global positioning system fixed data
$GPGLL Geographic position - latitude / longitude
$GPGSA GNSS DOP and active satellites
$GPGSV GNSS satellites in view
$GPRMC Recommended minimum specific GNSS data
$GPVTG Course over ground and ground speed
Next time you use Winfast CE, start it then tap on Tools - Command then the NMEA Tab.
Make a note of the settings then change them to the following:-
GGA 1, GLL 1, GSA 1, GSV 5, RMC 1, VTG 1. (Click OK)
Go back to Tools - Command. Make sure the re-set mode is set to Factory and un-tick the two Messages boxes, click OK.
It's better at this point to go outside under an unobstructed sky and wait. My unit, doing the above, finds first fix in around 37 seconds. If you do it inside, next to a window, it takes a lot longer.
davemk
PostPosted: Mon Nov 27, 2006 3:58 pm    Post subject: Reply with quote
I'll have another look and download the newer version. I'm going to run the monitor even though it's now working.....just out of curiousity to see what it brings up!!
Thanks again.
Border_Collie
PostPosted: Mon Nov 27, 2006 4:45 pm    Post subject: Reply with quote
I decided to have another 'fiddle' and found something rather interesting.
Instead of setting the $trings to GGA 1, GLL 1, GSA 1, GSV 5, RMC 1, VTG 1, I instead set them all to zero.
Went to Tools - Command, unticked the 2 boxes and did a factory re-set. about 37 seconds later I got a fix.
Went to View - Development and noticed the GGA, GSA and RMC $trings were showing every second and the GSV every five.
I re-checked Tools - Command -NMEA and all the settings were still showing 0.
Disconnected Winfast and started TT. To my suprise it worked fine and is working as well as, if not better, than previously. I hadn't expected that.
I'm not sure what this all means, so a few more experiments are about to commence.
