Posted: Fri Nov 24, 2006 10:32 am Post subject: |
Maybe it will be clearer to explain that one is for the Approach (1st) alert and the other for the Overspeed (2nd) alert. |
Mearns Lifetime Member
Joined: 24/08/2003 18:17:58 Posts: 162 Location: Aberdeen, Scotland
Posted: Sat Nov 25, 2006 3:44 pm Post subject: |
Ash10 - thanks for a superb piece of software! Used it with my new Nuvi 660 and it works perfectly.
Just wish the Nuvi could discriminate between co-located or closely located fixed and mobile cameras by just warning about one of them so I don't get a quadruple "bong"! _________________ Tony
nuvi 2460LT plus Brodit mount |
Hammer2006 Occasional Visitor
Posted: Sun Nov 26, 2006 7:51 pm Post subject: |
How do you go about uninstalling this application ??? ive got 2 installed by mistake and want to remove one of them. |
Ash10 Pocket GPS Verifier
Posted: Sun Nov 26, 2006 9:09 pm Post subject: |
Hammer2006 wrote: | How do you go about uninstalling this application ??? ive got 2 installed by mistake and want to remove one of them. |
If you mean that you've got two copies running in your system tray, just quit them both (using the Quit button in the settings window) - then run the application again (just the once, mind). |
Posted: Sun Nov 26, 2006 11:01 pm Post subject: |
I cant get to the settings as left or right clicking with my mouse wont open up the applications, they both just sit there saying camera manager idle |
imakora Occasional Visitor
Posted: Wed Nov 29, 2006 2:50 pm Post subject: |
Hi Ash,
Thanks for all the work you've put into the Camera Manager. Is there any way to alter the overspeed warning? I used to get a fairly constant "DING DING", but now have the warning repeating itself approximately every 5 secs. I'm not sure if this is a feature of your utility or not?
Regards, Ian. |
Posted: Wed Nov 29, 2006 4:38 pm Post subject: |
imakora wrote: | Is there any way to alter the overspeed warning? I used to get a fairly constant "DING DING", but now have the warning repeating itself approximately every 5 secs. I'm not sure if this is a feature of your utility or not? |
You can disable either/both of the approach and overspeed warnings, by setting the alert time to zero.
What you can't do however, is vary how often the overspeed warning sounds - that's dependant on your particular model of Garmin. On the i2/3/5 this is around once every second, on the Nuvi it seems to be nearer every five seconds or so. |
Posted: Thu Nov 30, 2006 6:10 pm Post subject: |
Many thanks Ash.
I've got a Nuvi, and it did give me an overspeed warning every second or so, but this has now changed to every 5 seconds. It must've changed with one of the Garmin updates.
Regards, Ian. |
Posted: Fri Dec 01, 2006 4:47 pm Post subject: |
Ash10, still need help please!! cos for the life of me i cant get rid of the bloody thing and ive tried all the normal ways.So any advice what be appreciated |
Posted: Fri Dec 01, 2006 9:36 pm Post subject: |
Hammer2006 wrote: | Ash10, still need help please!! |
Check your messages inbox - I sent you a PM last week... |
ianandrewhay Occasional Visitor
Posted: Mon Dec 04, 2006 3:26 pm Post subject: problems... |
i have a garmin i2 and am having problems with ash's software. I have windows xp and have downloaded the camera manager but it just says camera manager idle. When i try to load POI's from the garmin folder it says there aren't any in the folder.
i am using software version 3.20
Also a question- when i do load the POIs that the camera manager downloads onto the unit, will it automatically delete or overwrite ones i have loaded on before?? |
Posted: Tue Dec 05, 2006 9:57 am Post subject: Re: problems... |
ianandrewhay wrote: | i have a garmin i2 and am having problems with ash's software. I have windows xp and have downloaded the camera manager but it just says camera manager idle. |
Open the settings window and have a look at what is the latest database version, and the date it was last checked. |
Posted: Tue Dec 05, 2006 10:44 am Post subject: |
Current version: Speed Camera Database Version 4.115 30 Nov 2006
Last Checked: Monday, December 04, 2006 - 11:44:37 |
Posted: Tue Dec 05, 2006 11:18 am Post subject: |
ianandrewhay wrote: | Current version: Speed Camera Database Version 4.115 30 Nov 2006
In that case, Camera Manager has successfully downloaded the database.
If Camera Manager is idle, and is not reminding you that updates are ready - then it must think that you've already updated your Garmin (it does this whenever you run POI Loader).
Go to the settings window, change one of the timings slightly, then click on the OK button.
You should then start getting reminders to update (as you've effectively changed the database by specifying different timings). |
Posted: Tue Dec 05, 2006 11:40 am Post subject: |
thanks ash. I have now changed the timings, but as yet i have no reminders to update, is this normal?
I have previously manually downloaded a speed camera database onto the unit, do you think this is what is is detecting?
Also do any new updates automatically replace any previous ones? |
