Pocket GPS World :: View topic - Streetpilot I3 questions
nexus6
PostPosted: Sun Nov 19, 2006 10:16 pm    Post subject: Streetpilot I3 questions Reply with quote
Just bought an I3 from carphone warehouse for £99 and thanks to this excellent site with loads of knowledgeable people have installed all the speed cameras and poi etc. - thanks people.
Now for my questions.
1. If you are in route simulation mode can you speed it up ?
2. If you are using rechargeable batteries with the correct unit option selected do they get recharged via either the PC usb cable or the 12V car cable.
So far I think this is the best £99 I've ever spent !!!!
sunstrip_steve
PostPosted: Sun Nov 19, 2006 10:55 pm    Post subject: Reply with quote
In answer to 2 - no it does not charge them up unfortunately
Number 1, no idea. It is very slow!
Anita
PostPosted: Sun Nov 19, 2006 11:34 pm    Post subject: Re: Streetpilot I3 questions Reply with quote
Unfortunately, no. Sad
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
swanson2
PostPosted: Mon Nov 20, 2006 3:29 pm    Post subject: Reply with quote
Hi nexus6,
The answer to both your questions is No - but you are quite right that the i3 for £99 is extremely good value for money as indeed is membership of this site.
Personally I don't bother with rechargeable batteries, as the battery drain is so small when using the unit plugged into a car 12v supply, that my batteries last well over a year and so I just carry a couple of spare batteries in my car.
Robert Swanson
:D
I have enjoyed the past, but my main interest is in the future, because I am going to spend the rest of my life there!
philai3
PostPosted: Mon Nov 20, 2006 3:46 pm    Post subject: Reply with quote
I always use rechargeables, as I think the 12v socket on the I3 looks a little bit frail. Nothing wrong with it, but I want to plug/unplug as little as possible. I'm sure I've seen other posts where the little plastic bit in the middle of the socket has snapped off which would make it very difficult to use. As this socket is used for updating POI's as well, it'd be a bit of a disaster.
Garmin I3 October 2006
Garmin 1310 December 2009
(Firmware 3.2-2.7-3.4-2.7)
Renault Scenic with inbuilt Carminat Tom-Tom April 2013
Renault Clio
Mazda MX5 2010
swanson2
PostPosted: Mon Nov 20, 2006 3:55 pm    Post subject: Reply with quote
Hi philai3,
I have had two i3's for over a year and never had any problem with the input connectors.
I use both the car supply unit supplied by Garmin, and also a cheapie that I bought from Tesco for £5 and have never had a problem.
I wonder if any other forum members have suffered from fragile i3 connectors?
Robert Swanson
:D
ffrr
PostPosted: Tue Nov 21, 2006 2:10 am    Post subject: Reply with quote
I don't understand how using rechargeable batteries has any bearing on the use of the socket. You still have to swap the batteries when they are flat, same as for normal non-rechargeable batteries, and you don't need to remove the power cable to do that, in either case.
The main reason I remove the power cable is to hide the unit when parking in a public place, other than that, it's just the occasional time I need to connect it to my computer to add POI's or update maps and/or firmware (not often)
PaulB2005
PostPosted: Tue Nov 21, 2006 9:37 am    Post subject: Reply with quote
I think the point is that by using batteries we're not constantly stressing what is considered, by some people at least, a weak plug and possibly causing damage to the socket. At least this way we only need to use the socket when connecting to a PC and not every time we put the i3 in the car or take it out.
I hope you meant "remove from the car completely" so as not to be one of those in the Stolen GPS forum who will send my car insurance up by leaving expensive electrical equipment in their car, hidden or not.
IanE
PostPosted: Tue Nov 21, 2006 6:17 pm    Post subject: Reply with quote
Damn. I broke my i3 on Saturday by pulling the power cable out with my foot accidentally. Never realised that I won't be able to play with the firmware now. Crying or Very sad
philai3
PostPosted: Tue Nov 21, 2006 6:40 pm    Post subject: Reply with quote
The firmware is the least of your problems - you're probably better off sticking with whatever firmware works. It the POI's and speed camera updates you'll be missing!
Renault Clio
Mazda MX5 2010
IanE
PostPosted: Tue Nov 21, 2006 9:58 pm    Post subject: Reply with quote
Nope - I load em onto TF card.
Richard_Taylor
PostPosted: Mon Nov 27, 2006 6:15 pm    Post subject: Reply with quote
I can't open the battery door without pulling out the mini USB on the power lead. What's the trick?
My i3 is also a Carphone Warehouse £99 bargain, though it's now saying the map needs updating.
PaulB2005
PostPosted: Mon Nov 27, 2006 6:18 pm    Post subject: Reply with quote
please look at some of the other threads. This is well covered already.
ffrr
PostPosted: Tue Nov 28, 2006 8:59 am    Post subject: Reply with quote
I can open the door, but, when I posted, I had the usb cable from my computer plugged in. I see that it is hard to get one of the batteries past the right-angled plug that the car adapter uses.
PaulB2005
PostPosted: Tue Nov 28, 2006 9:38 am    Post subject: Reply with quote
right-angled plug that the car adaptor uses
Thats the problem. The lead that comes with the i3 isn't right angled. The original lead doesn't block the batteries, but your car charger from CPW does. You have no choice but to remove it.
