Pocket GPS World :: View topic - i3 battery Power/12v Supply Differences?
Neill
PostPosted: Mon Nov 20, 2006 11:52 am    Post subject: i3 battery Power/12v Supply Differences? Reply with quote
Apologies if this is an old question... I use the batteries mostly because the voice promps are much too early with the 12v lead. Is there something I haven't found that I need to set up manually for the different voltage? I notice she shouts a lot when fed 12v too... Laughing
I have software version 3.10 and Audio version 2.50
Thanks chaps Smile
PostPosted: Mon Nov 20, 2006 3:09 pm    Post subject: Reply with quote
The cig lighter plug drops the voltage from 12V so you are not feeding 12V into the i3. The difference in voltage from batt supply to car supply should not alter the functionality of the device, are you 100% sure of this "difference" - Mike
philai3
PostPosted: Mon Nov 20, 2006 3:42 pm    Post subject: Reply with quote
I usually use my I3 on rechargeable batteries, but on the odd occasion I've used the 12 volt lead, I think the volume goes up as well; also, I think I get less lock-ups/screen freezes if the batteries are freshly charged.
Garmin I3 October 2006
Garmin 1310 December 2009
(Firmware 3.2-2.7-3.4-2.7)
Renault Scenic with inbuilt Carminat Tom-Tom April 2013
Renault Clio
Mazda MX5 2010
bumpkin
PostPosted: Mon Nov 20, 2006 4:45 pm    Post subject: Reply with quote
Screen brightness and volume are reduced on batteries (I had always assumed to preserve power), I haven't noticed any other differences. I'm pretty sure that the voice prompts for turnings vary depending on the speed rating for the road, this might be what you're noticing. You get prompts nearer the turn around town as it's assumed you're going slower and also that the density of turnings will probably be higher so a later warning is beneficial.
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
Neill
PostPosted: Tue Nov 21, 2006 12:01 am    Post subject: Reply with quote
Thanks for your reply bumpkin, I forgot to say that the written screen prompts are perfect on both power suppies, only the voice promps on 12v seem a bit off.
Border_Collie
PostPosted: Tue Nov 21, 2006 1:34 am    Post subject: Reply with quote
I think it's more that as your rechargable batteries are only 1.2v each, 4 batteries = 4.8v not 6 and this causes the voice prompts to come too late. Idea Try using 4 fresh Duracell to see if there is a difference.
(I've assumed you use 4 x re-chargeable).
Flake
PostPosted: Tue Nov 21, 2006 1:56 am    Post subject: Reply with quote
i3 takes two AA batteries, not four.
Border_Collie
PostPosted: Tue Nov 21, 2006 2:08 am    Post subject: Reply with quote
Embarassed Thinking of one of my cameras.
So it's 2 x 1.2v = 2.4, whereas alkaline are 2 x 1.5 = 3v. Try TWO fresh Duracell.
My camera flash always gave up after about 10 flashes on rechargeable but Duracell had no problems.
PostPosted: Tue Nov 21, 2006 7:17 am    Post subject: Reply with quote
On the i3 you have a specific setting to inform the unit what type of battery you are using:
Settings/ System/ Battery Type in this menu are the two types Alkaline or NiMH make sure you have this selected to the correct value to avoid premature low battery warnings.
Lost Property, go out and treat yourself to some high power NiMH rechargeable, you can get AA NiMH batteries with a capacity over 2600mA/Hr - good for a few hundred flashes even with a powerful gun, and considerably cheaper in use! - Mike
Border_Collie
PostPosted: Tue Nov 21, 2006 5:27 pm    Post subject: Reply with quote
Thanks for that Mike. I tend to use my digital camera for nearly everything nowadays, although the flash is only good for around 15 feet, less than half the distance of my gun, it rarely gives a poor result and on the odd occasions it does I use One Step Photo Fix in Jasc Paint Shop Pro 9.
2600mA/Hr eh? It just shows you how long since I purchased rechargeables. :P But worth remembering if I sweep the cobwebs off my 35mm Canon AE1. (it will be it's 25th Birthday next year). Happy Birthday!
PostPosted: Tue Nov 21, 2006 7:06 pm    Post subject: Reply with quote
Off topic I know but the safety issue is relevent to any device using batteries.
If you do purchase high power capacity cells treat them with respect NEVER put them in you pocket with change/ keys - they gennerate significant heat (read burn) if shorted out - been there, not nice, invest in a small compartmented plastic box to house the cells in a safe way - Mike
Border_Collie
PostPosted: Tue Nov 21, 2006 7:33 pm    Post subject: Reply with quote
Thanks Mike, will do. I remember many moons ago, as a stupid teeneger, experimented by sticking a PP9 on my tongue. On Fire :P
I WOULDN'T ADVISE ANYONE TRYING IT!!!
paulyoung666
PostPosted: Tue Nov 21, 2006 10:38 pm    Post subject: Reply with quote
that is just a tickle , you want to try a whack from a stack of polythene , it smarts a lot 8O :D :D :D
