Pocket GPS World :: View topic - Speed Camera Database as Garmin POI map
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
TrevH
PostPosted: Tue Nov 21, 2006 12:14 am    Post subject: Safety Camera map overlay Reply with quote
where can I get the overlay map for my Streetpilot 2610 please 8O
Skippy
PostPosted: Tue Nov 21, 2006 1:20 am    Post subject: Re: Safety Camera map overlay Reply with quote
If you haven't already done so, pay your £2 (1 month) or £19 (1 year) to become a subscriber.
Follow this link:
http://www.pocketgpsworld.com/modules.php?name=Cameras
Select "Garmin" from the "SatNav System" drop down menu.
Select "UK - GPSR map overlay (Older GPS systems)" from the "Camera selections" drop down menu then click download.
The instructions and the installer are inside the zip file (get WinZip if you need something to unzip it with).
Good luck!
Gone fishing!
TrevH
PostPosted: Sat Nov 25, 2006 11:41 pm    Post subject: Reply with quote
Thanx, did it, done it, just need to try it out. Laughing
missing_user
PostPosted: Tue Dec 05, 2006 11:40 am    Post subject: Reply with quote
The database download page is still giving this misleading detail.
I had been waiting for the update and today found the update was available.
The Garmin GPSR database has not been updated yet
missing_user
PostPosted: Thu Dec 14, 2006 2:56 pm    Post subject: Reply with quote
Has this database been updated yet?
It appears to have been, but I have failed to get it to instal!
WiRED
PostPosted: Thu Dec 14, 2006 6:23 pm    Post subject: Reply with quote
I just downloaded the overlay, and it's definitely not what I sent them 24 hours ago. I guess it just hasn't found its way into the download system yet.
/WiRED
missing_user
PostPosted: Thu Dec 14, 2006 7:05 pm    Post subject: Reply with quote
The only choices I was given were 'Remove' or Repair'!!!
WiRED
PostPosted: Thu Dec 14, 2006 7:15 pm    Post subject: Reply with quote
Yes, that's what happens when you try to re-install the same version twice. What you've downloaded is what you already have from last time.
/WiRED
missing_user
PostPosted: Thu Dec 14, 2006 8:04 pm    Post subject: Reply with quote
Yet the download says:-
PocketGPSWorld.com Speed Camera Database
Version 4.123
13 December 2006
PostPosted: Thu Dec 14, 2006 8:12 pm    Post subject: Reply with quote
Clearly there is an issue, we'll investigate and report back Smile
PostPosted: Thu Dec 14, 2006 11:05 pm    Post subject: Reply with quote
i've only just uploaded it at about 9.30pm...
hence before that time it said 'not been updated yet' and now it says 'has now been updated'
WiRED
PostPosted: Fri Dec 15, 2006 10:41 am    Post subject: Reply with quote
I knew there'd be a simple answer Wink
To make the job of knowing what version you have just downloaded a little easier, I've worked out a way of putting the Version number in the .msi file. Starting from the next download, you should be able to hover your mouse over the .msi file (once you've extracted it from the .zip) and the version number will be displayed. Alternatively you can right-click on the file and check Properties, where it will be one of the fields.
/WiRED
missing_user
PostPosted: Fri Dec 15, 2006 10:53 am    Post subject: Reply with quote
[Friday 09:45]
It is still saying on the camera download page[with Google Map]:-
WiRED
PostPosted: Fri Dec 15, 2006 1:10 pm    Post subject: Reply with quote
Firstly, can I just gratuitously point out that this is my 100'th post 8)
Secondly,
strumble wrote:
[Friday 09:45]
True, but at least the map itself has been updated.
Thirldy, MaFt, is there any way that this can be automated so that when the map updates, the message on the download screen changes? Is there anything I can do which might help such as enclosing the version number in a text file for example?
/WiRED
PostPosted: Sat Dec 16, 2006 3:50 am    Post subject: Reply with quote
i forgot to change that reference to the GPSR overlay... i did remember the other 2 though!!
wired, the 'hover over the msi file' would be the best way for people to see the release version
Page 9 of 10
