Pocket GPS World :: View topic - customise/modify myn TomTom GO 300
James_patageul
PostPosted: Sun Nov 19, 2006 10:15 pm    Post subject: customise/modify myn TomTom GO 300 Reply with quote
Hello people,
i have receive a TomTom GO (4D00.001) (i think is the Go 300)
So i whant to change the splashscreen,add somes voices and more..
but when i connect myn TTGO300 on myn computer i dont see its "hardDrive" i only see the card reader device and of course the files inside the SD Card how is inside of the TTGO
i have installed the TomTom Home but seem not compatible with him :-(
So what can i do to customise a little myn GO 300 ?
Thanks...
Oldboy
PostPosted: Sun Nov 19, 2006 11:33 pm    Post subject: Reply with quote
If it is a 300, there is no Hard Drive.
When connected to the PC, via USB lead, it does only see what is on the SD Card. It acts like a Card Reader.
When the 300 boots up it loads everything it needs from the SD Card.
In which way does it appear that HOME is not compatible?
To change the Splash Screen, you need to change the splash.bmp File in the Root of the Card.
TT Via 135 App 12.075: Europe Map v1135
James_patageul
PostPosted: Mon Nov 20, 2006 5:47 pm    Post subject: Reply with quote
ok may be not hard drive inside of it, but at least memory inside of it !
because i can read in "setup" 32Mb Ram (free:14.9 mb) and this is not myn SD card because she have 128Mb
i have put one splash.bmp on the root of the SD card but nothing happen !
and for the home the error was something like
"sorry but your tomtom device is not compatible with tomtom home" Confused
PostPosted: Mon Nov 20, 2006 6:11 pm    Post subject: Reply with quote
There is nothing stored in the memory of the TomTom, everything is on the SD card. That is all you need to access (which you can do either with the Go plugged in via USB or by a card reader.
The splash screen WILL work if you have it named correctly.
One common mistake is calling it "splash.bmp.bmp" because you have windows set to hide file extensions (turn it off in Windows Explorer Tools menu / Folder Options / View tab).
It also has to be the right size and shape and rotated through 90 degrees. This has been discussed at length, try a search for "splash screen"
To get you started:
1. Select photo
2. Use any program to re-size (i.e. photoshop) to size 320 x 240 pixels
3. Rotate 90 degrees clockwise
4. Save pic in BMP format as splash.bmp on desktop
5. Plug in ttgo
6. Open ttgo in my computer
8. Copy the new splash.bmp from your desktop straight on to ttgo in same place
Miss out any of those steps and it won't show up.
James_patageul
PostPosted: Mon Nov 20, 2006 8:14 pm    Post subject: Reply with quote
Hello Andy,
ok, but what is very strange there was no splash.bmp originaly on the SD card (here the content of myn SD card)
Code:
F:.
|   benelux-3caba520.mds
|   CurrentMap.dat
|   belgique-10ee7dd6.mds
|   dan.vif
|   danm.vif
|   data.chk
|   data00.chk
|   data01.chk
|   data02.chk
|   data04.chk
|   data05.chk
|   data07.chk
|   data08.chk
|   data09.chk
|   data10.chk
|   data11.chk
|   data12.chk
|   data13.chk
|   data14.chk
|   data15.chk
|   data16.chk
|   data17.chk
|   data18.chk
|   data19.chk
|   data20.chk
|   data21.chk
|   data22.chk
|   data23.chk
|   data24.chk
|   deuf.vif
|   deum.vif
|   engf.vif
|   engm.vif
|   esp.vif
|   espm.vif
|   fraf.vif
|   fram.vif
|   ita.vif
|   itam.vif
|   nld.vif
|   nldf.vif
|   nldm.vif
|   nor.vif
|   norm.vif
|   sve.vif
|   svem.vif
|   system
|   tomtom.aid
|   ttgo.bif
|   ttsystem
|   usaf2.vif
|   usaf3.vif
|   usam.vif
|   vla.vif
+---Belgique-Map
|       belgique.mid
|       belgique.pna
|       cline.dat
|       cname.dat
|       cnode.dat
|       faces.dat
|       mapinfo.dat
|       poi.dat
|       belgique.mms
|       Belgique-Map.cfg
+---Benelux-Map
|       benelux.mid
|       benelux.pna
|       cline.dat
|       cname.dat
|       cnode.dat
|       faces.dat
|       mapinfo.dat
|       poi.dat
|       benelux.mms
|       Benelux-Map.cfg
\---TomTom-Cfg
        birthday.txt
and also some pictures
boot
Edited after request - Oldboy
James_patageul
PostPosted: Tue Nov 21, 2006 9:12 pm    Post subject: Reply with quote
no body can help me ?
James_patageul
PostPosted: Tue Nov 21, 2006 9:21 pm    Post subject: Reply with quote
ho btw the 4D00.001 seem be a TomTom classic if can help to resolve my problems.
PostPosted: Tue Nov 21, 2006 9:57 pm    Post subject: Reply with quote
Give us a chance....
Tomtom classic did not come with a splash screen so not strange at all. From your pictures you still have v4 software, as far as I remember you need to be on v5 at least for the splashscreen to work.
Get a larger SD crd and copy the original onto that. Put the original away safely. Then update your software.
Incidently, it is not a good idea to post photos that show the device code of your hardware or product code of your maps.
keenster
PostPosted: Tue Nov 21, 2006 10:41 pm    Post subject: Reply with quote
thats definately a classic not a 300
James_patageul
PostPosted: Tue Nov 21, 2006 10:56 pm    Post subject: Reply with quote
Andy_P2002 yeap the problem was because i was running a older software version (4.00)
Users of an original TomTom GO need to install TomTom GO software update 5.00 or higher in order to be able to use premium voices, colour schemes and other downloadable TomTom PLUS items.š
thank's to all
22.094 (25 Sep 24)
