RICKT Regular Visitor
Posted: Wed Nov 15, 2006 9:08 pm Post subject: URGENT - TT 710 - FROZEN - CANT RESET IT!!! |
Every since i put the latest software via TOMTOM the other my item would not turn off, when it went to power off.. it would just restart..
TODAY... went to turn it off and it restarted like always... however now the screen is black, "Black" with light/power ie likes it tunred on just displaying a black screen if you get what i mean...
So tired a reset... wont do anything at all.. removed the SD card.. put power it in it... LED lights green... screen does not change...
is there any way to remove the battery?? or is it just the case of leaving it till ot goes flat and see what happens if anything...
if its completly knacked... hows the best way to get TT to repair it?? the item is only 5 months old..
how long does it normally take TT to do these things??
Many Thanks
Rickt |
Posted: Wed Nov 15, 2006 9:10 pm Post subject: |
Try holding the reset switch (its near the power connector under the unit where the mount connects) pressed with a pin for 30 seconds then see what the device does - Mike |
Posted: Wed Nov 15, 2006 9:17 pm Post subject: |
I was pressing Reset for about 10 seconds each time.done it about 20 times!! i have just put it onto my docking station, released it and tried again... no joy.........however just held the reset in for 30 seconds and its reset!!! loaded up ok... just doing a few shut downs restarts as we are speaking!!
how strange tho... i would of thought 10 secs was long enough??
(it still hangs for 26 seconds on the green shutdown screen tho!!)
Cheers for that.... from when i stated typing this i have donee about 5 reboots and seem to be ok!!
many thanks
Rickt |
Posted: Wed Nov 15, 2006 9:20 pm Post subject: |
any one else had issues with version 6.520???
Rickt |
biggles150 Lifetime Member
Joined: Jan 09, 2006 Posts: 101 Location: Eltham, London
Posted: Wed Nov 15, 2006 9:48 pm Post subject: |
The hang on the shutdown screen is normal. _________________ Go Classic
Application 7.163 (8493/71205)
OS:2328
GB Map v710.1571
Sandisk ultra II 512MB |
Posted: Wed Nov 15, 2006 11:08 pm Post subject: |
it shutdown fine before i updated the version tho... i cant understand why TOMTOM would release this knowing shutdown takes longer...
If i renamed the shutdown screen would it close quicker... or i guess it would just hang for the same period of time just without a splash..?
Rickt |
sgould Frequent Visitor
Posted: Wed Nov 15, 2006 11:40 pm Post subject: |
How much spare space is left on the card? It may be too full to work correctly. It needs space for temporary files.
Have you deleted any unneeded voices to make more room?
On my Apple Mac, I find that the Trash (recycle bin) is set for each drive separately and it is not deleted on shutdown/removal. You have to physically empty it to release the space taken up on the card by the files you put in it. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Wed Nov 15, 2006 11:57 pm Post subject: |
im running off a 1GB Scandisk SD card... im not a fan of using the original...like to keep it how it was out of the factory!! (i like to keep it locked away under lock and key at home!!) also if i come to sell the unit its easy with no messing about removing stuff etc...
i have loads of POI's, few voices... (which im going to get rid of but not have chance) well to have about 95 POI's (Europe speed cameras and a load of other boring stuff which i may need one day!! u know how it is!!)
apart from that its pretty much standard.. its just since i updated it the other day to 6.520, it seems to be running like a dog.. (not a greyhound!)
thinking of reverting back a version and take it from there..... however im just intrested to see if any one else has been having issues?
Does any omne know when the next software release is from TOMTOM??
Rickt |
Posted: Sun Nov 19, 2006 11:53 pm Post subject: |
Rickt |
shauneco Regular Visitor
Joined: Feb 10, 2006 Posts: 135 Location: Mansfield,Nottinghamshire
Posted: Mon Nov 20, 2006 10:58 am Post subject: |
Hi I had simalar issue's with my 2 GB Datawrite SD Card, I had to format it and start again now works perfect and very fast with the latest V6.52 firmware. |
coblator Occasional Visitor
Posted: Mon Nov 20, 2006 3:34 pm Post subject: |
HI
I HAVE A TOMTOM 710 AND I HAVE FOUND A SPEED CAMERA ICON ON IT THAT SHOULD NOT BE THERE AS IT IS ON A SMAAL SIDE STREET ALSO I HAVE UPDATED IT VIA THE DISC SUPPLIED AND SPEED CAMERAS ARE NO LONGER POIs WHEN THEY WERE POIs YOU COULD CHANGE THE DISTANCE IT WARNED YOU ALSO I DONT SEEM TO HAVE THE MOBILE SITES COMMING UP ON IT FOR SOME REASON IT ONLY PICKS UP GATSOs CAN ANYONE HELP ME WITH THESE POINTS
THANKS PHIL D |
Andy_P Pocket GPS Moderator
Posted: Mon Nov 20, 2006 4:25 pm Post subject: |
STOP SHOUTING!
Thank you. 8) (oh, and punctuation helps people to understand what you are saying too).
From what you say, ("SPEED CAMERAS ARE NO LONGER POIs") it sounds like you are using TomTom's own camera database rather than the one from this site.
If so, then I'm afraid it is tough - TomTom have changed the way they do their cameras and you now can't change either the distance or the warning sound. No-one who posts on the forums seems to like it. Suggest you e-mail TomTom support and tell them that you don't either.
The alternative is to get the database from here, which still works as POIs.
As for finding a spurious camera icon, you can report that to TomTom too, and if you find one in the PGPSWorld version you report that on the same page as where you download the database from:-
Camera download page (You need to be a registered member before that page will work. £2/month or £19/year). |
Posted: Tue Nov 21, 2006 12:39 am Post subject: |
HI ANDY
THANKS FOR THE REPLY I DID DOWNLOAD FROM TOMTOM THAT WAS OF THE DISC SUPPLIED AND I WILL E MAIL TOMTOM RE THE ROUGE CAMERA I THINK THESE THINGS ARE SOMETIMES MORE TROUBLE THAN THEY ARE WORTH THANKS FOR THE INFO
REGARDS PHIL D |
