veehexx Occasional Visitor
Posted: Mon Nov 20, 2006 12:58 pm Post subject: PDA backup issue TT6 |
i done a google search for backup issues on PDA's running TT6 - found 1 or 2 places that are having similar issues.
basically: if i install and run TT6 on my PDA, exit and then try and do a full backup to SD card, it will fail on the "navigator.exe" file. every single time.
i never had an issue with TT5 - always backed up perfectly, it's just an issue with the latest TT6 .exe file.
i'm running an acer N35.
also, 2 other questions:
1) the main reason im trying to get backup working is that TT seems to store the 'favorites' in ROM memory. so if the battery goes completely flat, i loose my contacts. same as if i have todo a hardreset for whatever reason, i'll loose my favorites. if there is a way to backup my 'favorites' without doing a full backup of the PDA, then that would be great.
2) is the n35 powerful enough to hand tt6? it just seems to take a while to update the screen. not so much an issue on the motorway etc, but more around town with twisty and lots of corners. i found it can take around 200-300yards before it updates my location properly.
its not a signal issue. using an external high-gain ariel that always reports full bars in TT. |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Mon Nov 20, 2006 7:47 pm Post subject: |
I don't know about the other questions you raised, but in TT5 the Favourites were store in the Map Folder in a File called Map_Name.cfg
In TT6 it stored in a File called MapSettings.cfg, also in the Map Folder. _________________ Richard
Posted: Mon Nov 20, 2006 8:49 pm Post subject: |
well, that worked. thanks
it's a long-term backup fix till TT sort out the full PDA backup issue. obviously a bug in TT6 or something cuz it was fine with TT5. |
Border_Collie Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
![](modules/Forums/images/avatars/846718549526d5fd14b726.jpg)
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Mon Nov 20, 2006 9:23 pm Post subject: |
The Aver N35 has a 266MHz Processor: I believe the recommended minimum is about 350MHz. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Posted: Tue Nov 21, 2006 10:48 am Post subject: |
350mhz+ eh? that could very well explain why it's slow to update!! never thought about processor speed really.
time to dig out me copy of tt5... |
Posted: Tue Nov 21, 2006 5:32 pm Post subject: |
Quote: | time to dig out me copy of tt5... |
But wait, Christmas is just around the corner, a nice big hint for a new PDA, aimed towards wife, partner, mum, dad, children, could well see a suprise in your Christmas stocking. :P _________________ Formerly known as Lost_Property
derek500 Occasional Visitor
Posted: Tue Nov 21, 2006 6:25 pm Post subject: Re: PDA backup issue TT6 |
[quote="veehexx"]i done a google search for backup issues on PDA's running TT6 - found 1 or 2 places that are having similar issues.
quote]
I've got TT 6.010 on my N35 and have no problems backing up/restoring to the SD card or with the PC using Activesync.
The Tomtom website says that the N35 is supported with TT6 |
