Pocket GPS World :: View topic - i3 Warning Sound buzz (failing)
Sent
PostPosted: Sun Oct 29, 2006 3:13 pm    Post subject: i3 Warning Sound buzz (failing) Reply with quote
I've had my i3 for almost a month. I turn on the warnings that add the ping before each command. A couple days ago the ping started sounding awful and buzzy, is this normal? The normal commands are just fine though, which is weird. So for now all I've done is turn off the warnings.
Sent
PostPosted: Tue Oct 31, 2006 9:43 pm    Post subject: Reply with quote
So no one with an i3 has had their sounds start buzzing ?
ffrr
PostPosted: Wed Nov 01, 2006 12:13 am    Post subject: Reply with quote
Mine has always sounded a little buzzy (I've had it nearly a week). I put it down to a lowish sample rate used when creating the sound, and also that I have the volume on full.
I can hear a few sampling artifacts in the speech as well, but it is certainly good enough for the intended purpose, so I didn't worry.
COMANDOOO
PostPosted: Sat Nov 18, 2006 11:59 pm    Post subject: Reply with quote
hi my sound has failed!
started buzing then stopped unit 12 months old.
will advise result of repair.
paulyoung666
PostPosted: Sun Nov 19, 2006 11:17 pm    Post subject: Reply with quote
is a repair worth it when you can buy new for £99 from carphonewarehouse Wink
22.071 (03 Jul 24)
