fourfive Occasional Visitor
Posted: Sat Nov 18, 2006 5:23 pm Post subject: Nokia N80 & TomTom, Problem? |
Hi, i have tomtom 6 up and working on my nokia n80, but when the voice speaks to give instruction the map pointer stops until the voice stops and then the map pointer jumps forward to actual position. Is this delay normal? |
SimonCatlin Frequent Visitor
Posted: Sun Nov 19, 2006 11:35 am Post subject: Re: Nokia N80 & TomTom, Problem? |
fourfive wrote: | Hi, i have tomtom 6 up and working on my nokia n80, but when the voice speaks to give instruction the map pointer stops until the voice stops and then the map pointer jumps forward to actual position. Is this delay normal? |
Do you have any other software running at this time? e.g. music player etc.. Have you upgraded to V4 of the firmware?
Mine does not, have this problem, well not that I have noticed, although it seems that it can be about a second behind on your location. _________________ iPhone5, TomTom, Google maps, Navfree, Viewranger and Apple Maps (ekk) |
philhoward Occasional Visitor
Posted: Mon Nov 20, 2006 9:34 pm Post subject: |
I've noticed this as well - slight problem when there's a series of instructions and the map stops whilst Jane (or whoever) goes through them all!
I've also had it lock up on me within 45 mins of running - phone reboot was the only solution.
Just running Nokia update to see it that helps...it made my N70/TT5 better (but still locked up after a while). I wait with baited breath! |
adamf Lifetime Member
![](modules/Forums/images/avatars/2404478364437ecc2a2344.jpg)
Joined: Jul 31, 2004 Posts: 410 Location: wolverhampton
Posted: Fri Dec 08, 2006 9:28 pm Post subject: |
type *#0000# in to the n80 this will show the phone software version it needs to be v4 or higher you can update the phone software via nokia support |
Posted: Sat Dec 09, 2006 9:03 pm Post subject: |
Just checked mine and its running 4.0623.0.41, so definately v4.xx and it still does it. Starts to lock up after an hour or so's driving as well, bit of a pain especially as its usually as I approach the fiddly bits soming up to my destination! |
Biggins Occasional Visitor
