Screamer777 Lifetime Member
Posted: Thu Nov 16, 2006 12:48 am Post subject: Newbie: POI Loader & Camera POI's |
Hi all, was wondering if you can help me. I've subscribed to the website, downloaded the camera DB, downloaded the newst POILoader from Garmin and installed it.
Hardware is a Nuvi 310D.
However I cant get the POILoader to recognise anything. Specifically: I connect the Nuvi via USB, the little graphic comes up on the Nuvi's screen and XP pops up a dialog box for me to do stuff with the removable drive.
I fire up POILoader and all I see is the text "Welcome to POILoader... ...where your Garmin GPS can read it.". There isn't any buttons to press on the application, simply nothing at all. I uninstalled it and redownloaded it to no avail as well.
I've downloaded the instruction pdf from this website and it looks as though I should have a 'Next' button or something. If I open up the webupdater software it does find my device, but beyond that I'm stumped.
So does anyone have any ideas please as I would like to have a play with it on my way to work tomorrow.
Thanks in advance.
S |
Anita Pocket GPS Moderator
Posted: Thu Nov 16, 2006 1:46 am Post subject: |
Don't know the Nuvi, but just a thought. I had to install drivers from the CD-ROM that came with my i3 before connecting it to the PC. Have you? _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Posted: Thu Nov 16, 2006 2:21 am Post subject: |
Hi Anita, thanks for the post. I checked the included disk and manual. In the manual it doesn't say to install any drivers. On the disk there were .inf files so I installed them regardless figuring it cant make it any worse, however still no joy.
I'm tempted to just copy them across to the drive but I'm not sure if this is enough...
Any other suggestions??
Cheers,
S |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15157 Location: Bradford, West Yorkshire
Posted: Thu Nov 16, 2006 2:38 am Post subject: |
i remember seeing this before on the forum and i think it was to do with screen resolution messing up the display of poi loader or something...
there should be a button that says 'find device' which, when pressed, pulls up a list of the 'removable devices' - try searching the forums for it or try reinstalling the poi loader software.
as you suggest, you can't just copy the files to the nuvi as poi loader converts everything to its own format.
MaFt |
Posted: Thu Nov 16, 2006 4:06 am Post subject: |
I just had a quick look through some posts but didn't spot anything likely. I had a quick try as well at changing the resolution of my monitor with no luck either.
Picture being a 1000 words and all I've taken a screenie of what Im presented with. Hopefully will help.
http://www.zodiacamateurproductions.pwp.blueyonder.co.uk/Nuvi-Probs1.JPG
Thanks to all,
S |
mrgthomas Occasional Visitor
Posted: Thu Nov 16, 2006 8:07 am Post subject: |
When you plugged in you sat nav for the first time did it install it all onto Windows automatically as you do appear to have a button or two missing from the POI Loader screeen ? 8O |
Posted: Thu Nov 16, 2006 1:03 pm Post subject: |
I.e. When I first installed Mapsource? It did nothing except bring up the removable drive prompts IIRC.
However your correct in saying that I have buttons missing from the POILoader screen, I included a link to a screenshot showing this, and itf memory serves I've never seen any buttons with this application....
Cheers,
S |
swing Pocket GPS Verifier
Posted: Fri Nov 17, 2006 10:53 am Post subject: |
This has been covered before on the forum....
There are a number of possible fixes, but firstly, are you running the latest POI Loader available from Garmin (as this should fix this problem) v2.3.2.0.
However, is your taskbar at the top of the screen? If so, move it to the bottom and it'll work fine.
If not, then have you set any different settings - changed default system font, increased the dpi for easier viewing, got any of the accessibility options turned on? Many programs don't fully cope with these, and they coiuld be the cause. |
Posted: Fri Nov 17, 2006 12:29 pm Post subject: |
looks like you're running vista... either that or you've changed various settings to affect the display - so it could be that
MaFt |
Posted: Sun Nov 19, 2006 11:37 pm Post subject: |
Thanks for all the suggestions, I do have my taskbar at the top and when I moved it back to the bottom it worked fine. Strange.
I did have a good go through the forum with the search utility but didn't spot the fix. My thanks to you Swing and MaFt for your help.
I'll also pass it on to the chap in Garmin who was trying to help.
Cheers,
S |
