Pocket GPS World :: View topic - Sounds
Sounds
Trigger
PostPosted: Wed Nov 15, 2006 9:32 am    Post subject: Sounds Reply with quote
I have Just updated my TOM Tom 700 to new the Latest Version 6.520.
use to ogg file but get horns, bell etc before the warning Sound.
Is there any awy of removing this as it is driving me mad.
I am new to this so any help would ge great
JohnLittleton
PostPosted: Wed Nov 15, 2006 2:53 pm    Post subject: Reply with quote
The ogg files must be the exact same file name as the coresponding bmp and ov2 files, only the file extension is different. The ogg files reside in the map folder along with the other POI files.
Once installed re-configure you warnings and it will use the ogg sounds - Mike
Trigger
PostPosted: Wed Nov 15, 2006 4:23 pm    Post subject: Reply with quote
I have done all that but I still get a boing sound before the spoken sound this is the sound that I want to get rid off.
JohnLittleton
PostPosted: Wed Nov 15, 2006 5:01 pm    Post subject: Reply with quote
Sounds like you may have two instances of the database installed at the same time?
Turn off ALL your POI warnings then just enable ONE of the camera ones with an ogg sound. Run a demo route past a camera and see (or hear) what you get then...
Trigger
PostPosted: Thu Nov 16, 2006 8:31 am    Post subject: Reply with quote
Thanks Andy _P2002 done that but still get the Siren before the Voice Warning any other ideas.
I sthere any way of finding out if I have two instances of t6he database installed.
JohnLittleton
PostPosted: Thu Nov 16, 2006 8:38 am    Post subject: Reply with quote
Does the ogg Files themselves have the Siren in them? Have you tried any of them in a Sound Editor?
Have you installed the TT Cameras as well?
To find which POI's you have installed, just count up the number of Speed Camera related OV2 Files in the Map Folder.
Mullet
PostPosted: Thu Nov 16, 2006 8:40 am    Post subject: Reply with quote
Are you using a modified data.chk or the original?
Trigger
PostPosted: Thu Nov 16, 2006 8:43 am    Post subject: Reply with quote
Moddofied data. chk
This one Liz oggs 22050 HZ renamed
JohnLittleton
Mullet
PostPosted: Thu Nov 16, 2006 8:48 am    Post subject: Reply with quote
It is my understanding that you problem occurs if you are using a modified data.chk with the .ogg method. Revert back to the original and see what happens.
Trigger
PostPosted: Thu Nov 16, 2006 8:55 am    Post subject: Reply with quote
Looking on my 700 hard Drive I have 3 Dat Chk
7120_new.data.chk
data.chk
data05.chk
Could it be one of these effecting the sounds.
JohnLittleton
PostPosted: Thu Nov 16, 2006 11:45 am    Post subject: Reply with quote
The datao5.chk File is the english female voice, aka as Jane.
The data.chk File is the current warning sound File.
The 7120 is the downloaded modified data.chk File.
There can be only be 1 warning per POI, therefore there are 2 POI's for that location, or the Warning has that combination of sounds that you hear.
Trigger
PostPosted: Thu Nov 16, 2006 12:45 pm    Post subject: Reply with quote
Thqanks
Is there any idea of finding out which is which.
Or do I have to put uo with it
JohnLittleton
PostPosted: Thu Nov 16, 2006 8:22 pm    Post subject: Reply with quote
Have you loaded the TT cameras at any time?
If yes, take them off the card. You can delete them from HOME, I believe.
Is the data.chk File that you have, the original?
If it is, at least we are starting with a clean sheet.
If you go to Warn When Near are you asked which Warning Sound you want?
If it can see an associated ogg File, (one with the same File name) it won't ask you to select a Warning Sound.
How many Camera POI's do you have in the Map Folder? Have they all got corresponding ogg Files?
Just count the OV2 Files, and see if each one has a OGG File.
Can you play the ogg File that seems to be giving the problem?
I use Sony SoundForge, but there are quite a few that can read ogg Files.
Trigger
PostPosted: Thu Nov 16, 2006 9:13 pm    Post subject: Reply with quote
All Ov2 files have a ogg.
Use Camera base of PocketGPSworld never used TT
Get Siren then spoken alert
I belive it is the original datachk file but not sure any way to check
JohnLittleton
PostPosted: Thu Nov 16, 2006 9:23 pm    Post subject: Reply with quote
Possibly check the date on the File.
If you have a Backup from right after you Upgraded, you can Copy it from your PC.
You didn't say how many OV2 Files you have!
But from what you're saying it looks as if the Sounds you hear are already in the ogg Files. The original Liz Files didn't come with any Extra Sounds, so I'm at a loss.
Just do a count up first.;)
22.063 (19 Jun 24)
