Mashford Occasional Visitor
Posted: Tue Nov 14, 2006 8:56 pm Post subject: Help Please!!!!! |
I was hoping someone could help me with a couple of problems I am having with Sat Nav.
I keep getting Asset Failure coming up and would like a possible solution to correct this.
Addtionally when I attempt to go into addy or POI the smaill egg time thing comes up on screen and stays there normally followed by Asset Failure.
And finally if I go to map the same a sound come on and doesnt stop(it sounds like the warning for Speed cameras.
Someone out there please help
Thanks |
Gee-Pee Lifetime Member
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Tue Nov 14, 2006 10:08 pm Post subject: |
It would be helpful to know what you device is If it is the Navman iCN 5xx, then try a hard reset (Switch off the battery at the back of the device, wait a couple of minutes and then switch on again).
This has been known to solve the problem - it did for me. If that does not help, post all the details - that is your GPS Device, the software you are using and the exact details of the Assert failure message. _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
robertn Frequent Visitor
Posted: Tue Nov 14, 2006 10:16 pm Post subject: |
Have a look at previous posts on this problem "Search" is you friend. Replacing and/or Reformating SD cards and reloading software often fixes these issues. |
Posted: Tue Nov 14, 2006 10:50 pm Post subject: |
I have tried the reset and turning the batterery off and leaving it for a while but once I turn unit back on and go to address or POI the timer comes on and stays on then I would get error message "assert failure Navigator\gui\unstable\apps\destwizard.c
LINE 2004
Test Country result!=null.
My sat nav is a navman 520i using smartST 2005 software
Hope this is enuff
Posted: Wed Nov 15, 2006 12:10 am Post subject: |
Mashford wrote: | Hi
LINE 2004
Hope this is enuff
Sounds like a problem for Navman. See this thread, which is similar - there are others...HERE
