Pocket GPS World :: View topic - Lost six digit pastcode search
Munsters
PostPosted: Tue Nov 14, 2006 8:41 pm    Post subject: Lost six digit pastcode search Reply with quote
Since changing my SD card in my TomTom I have lost the use of the six digit feature for my search. Does anyone know how I can reinstall this feature? I have all the latest updates.
Munsters
PostPosted: Tue Nov 14, 2006 9:31 pm    Post subject: Reply with quote
I do not have a file called zip as talked about on previous threads. I have got a file called tomtom but htis seems to make no difference.
PostPosted: Tue Nov 14, 2006 9:53 pm    Post subject: Reply with quote
Do you still have the original SD card? - if so copy the zip folder to the new card - it contains the postcode data file. If not load the CD for the GB map and select the postcode option to install - Mike
RICKT
PostPosted: Tue Nov 14, 2006 11:42 pm    Post subject: Reply with quote
how about just trying to copy all again from the SD card... threres no reason it should fail
Rickt
Munsters
PostPosted: Wed Nov 15, 2006 10:54 am    Post subject: Reply with quote
I deleted some postcodes off the old SD card to make way for other files so copying the SD card would be a waste of time. When I try to boot the CD I got with the product it says that there is not enough space on my temporary drive? Not sure what to do next. Thanks for your replies.
PostPosted: Wed Nov 15, 2006 8:06 pm    Post subject: Reply with quote
Munsters wrote:
I deleted some postcodes off the old SD card ...
I'm presuming then that you must have had the old Postcode POI system.
What Device do you have?
Which Version of Software are you running?
What size SD Card do you have?
Just a few questions that will help to give the correct (hopefully) answers.Smile
TT Via 135 App 12.075: Europe Map v1135
Munsters
PostPosted: Tue Nov 21, 2006 11:50 am    Post subject: Reply with quote
The unit is a Go 300 running App 6.520 OS:1387 GPSv1.21, Boot 4.86
Map v562.0
I have a 2Gig Toshiba SD card.
PostPosted: Tue Nov 21, 2006 9:23 pm    Post subject: Reply with quote
I think THIS is what you want.
Munsters
PostPosted: Wed Nov 22, 2006 12:47 am    Post subject: Reply with quote
Thanks for your help. Where do I go with the link. Sorry not too technical. Do I need to wipe my SD card?
Munsters
PostPosted: Wed Nov 22, 2006 12:50 am    Post subject: Reply with quote
I have Tom Tom Home installed on my PC will this deter me from fixing my problem? The CD info does not show any guidance to install the postcode files.
PostPosted: Wed Nov 22, 2006 1:18 am    Post subject: Reply with quote
Extact all files from the zip archive and save on PC
Connect Go to PC, do not run home
Run setup.exe from the extracted archive
Follow the instructions.
Finished folder on TT is 8.4Mb
Munsters
PostPosted: Thu Nov 23, 2006 7:54 pm    Post subject: Reply with quote
Thanks. Will be away working for four days. I'll let you know how I get on when I get back.
Munsters
PostPosted: Wed Nov 29, 2006 8:42 pm    Post subject: SORTED Reply with quote
Hooray, problem solved. Thanks to everyone who helped me out. My travelling will run much smoothly from now on. If only Tom Tom support could be as useful as you guys!!
22.094 (25 Sep 24)
