dundeered Occasional Visitor
Joined: Nov 08, 2006 Posts: 28 Location: broughty ferry
Posted: Sun Nov 12, 2006 11:04 pm Post subject: data missing |
sometimes when i copy voices over to the voices folder then disconnect then go back in there no longer on card, this is happening with pois for speed cameras??
using tom tom 510 , 1gb sd card, anyone else come across thjis and got a solution?? |
Posted: Sun Nov 12, 2006 11:37 pm Post subject: |
done it again , copied everything across disconect then nothing...reconect to pc and files missing . |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Sun Nov 12, 2006 11:38 pm Post subject: |
In your Task Bar there should be an Icon labelled Safely Remove Hardware. It could be that due to caching, not all the information has been written to the Device before you disconnect it.
Using the mentioned Function will ensure that all Data has been written to the Device before disconnection. _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
uptowndisco Regular Visitor
Posted: Sun Nov 12, 2006 11:41 pm Post subject: |
dundeered wrote: | done it again , copied everything across disconect then nothing...reconect to pc and files missing . |
Depends on the area of Dundee you live, they will steal anything as soon as your back is turned :D
Dunno what to sugest though. |
Posted: Mon Nov 13, 2006 1:17 pm Post subject: |
i know thieving little ... luckily i live in the fur coat no knickers area of broughty ferry. . posh as down there
ill give safely removing hardware option . |
