coastersteve Regular Visitor
Joined: 06/05/2003 18:01:04 Posts: 83 Location: United Kingdom
Posted: Fri Nov 10, 2006 2:09 pm Post subject: |
That's great, but what it doesn't show is how it's spliced in to the TMC reciever itself. |
Wildoat Occasional Visitor
Posted: Fri Nov 10, 2006 2:49 pm Post subject: |
I have one of these and as yet not tried a long journey but left Tom Tom on in the car outside for 2 hours and nothing - just has a greyed out circle and says No Info Available - no indication that it is trying to tune in to anything.
What should I be seeing or does this just indicate that there is no reception? (I have updated to latest version for 910 and no difference).
It would be a help to know what to expect as at the moment I havnt a clue!
W |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Fri Nov 10, 2006 3:01 pm Post subject: |
A grey circle means it recognises the connection to the TMC device but it can't even find a station to lock onto, let alone the correct one (ClassicFM).
Tap the screen then tap on TomTom Traffic. This screen will tell you what, if any, station you are connected to. Try selecting the UK as your country, as opposed to the strongest signal.
Ensure that the TMC module has the cable stretched out, not coiled up. _________________ Tim |
Posted: Fri Nov 10, 2006 3:24 pm Post subject: |
I took mine in home and dangled the TMC bit out the window, set it to strongest signal and left it. Every now and then it'd then show frequency and RDS name of the station it was glued too but only when in the traffic menu. Even when it did find Classic FM no data was found  |
TonyHoyle Regular Visitor
Posted: Fri Nov 10, 2006 3:27 pm Post subject: |
coastersteve wrote: | That's great, but what it doesn't show is how it's spliced in to the TMC reciever itself. |
I don't think it is - there's no mention of modifying the TT TMC receiver itself.. in fact he says he didn't use it on a TT - "There was little point connecting the TomTom Go-910 as it seldom drops below full reception strength!" - definately not talking about TMC here!!! |
Posted: Fri Nov 10, 2006 3:30 pm Post subject: |
(damn this forum needs an edit function..)
Later on he talks about connecting an aerial to a TMC receiver, but it is definately *not* a tomtom one - "Then you simply plug the new cable into the TMC unit, switch on and wait to achieve a signal lock". There's nowhere to plug an external aerial in the TT TMC.. |
Posted: Fri Nov 10, 2006 3:48 pm Post subject: |
coastersteve wrote: | I took mine in home and dangled the TMC bit out the window, set it to strongest signal and left it. Every now and then it'd then show frequency and RDS name of the station it was glued too but only when in the traffic menu. Even when it did find Classic FM no data was found  |
Yes, you only get to know what you're connected to on the Traffic screen. _________________ Tim |
Posted: Fri Nov 10, 2006 5:00 pm Post subject: |
TonyHoyle wrote: | there's no mention of modifying the TT TMC receiver itself.. in fact he says he didn't use it on a TT - "There was little point connecting the TomTom Go-910 as it seldom drops below full reception strength!" - definately not talking about TMC here!!! | The actual quote you guys are refering to is with respect to the GPS aerial that is also fitted within the Hirschman unit, the GPS reception on a Go-910 is nothing short of perfection, I only want to point out this basic miss quote as it is out of context with respect to this thread - Mike |
lydiachris Regular Visitor
Posted: Sat Nov 11, 2006 1:06 pm Post subject: |
Has anyone ordered one from the TomTom site yet and got i direct?! I know there been alot of arguing about wether or not they are different units or updated ones, but i'm just interested if the TMC units from the tomtom website direct are any better?
Would be interesting to know!!
Cheers,
Hey this is my 200th post :D :D :D
Do i get a prize!?!?!  |
classy56 Frequent Visitor
Posted: Sat Nov 11, 2006 4:28 pm Post subject: |
Of course you get a prize !!! An imported TMC reciever...enjoy. _________________ Tomtom Go730T
App 8.300
Map v815.2003
To old to die young. |
Posted: Mon Nov 13, 2006 10:14 am Post subject: |
Does anyone have one to hand? If so could they measure the wire from jack plug to the TMC unit please. If TT have done their homework it should be around 9ft which will be tuned to around 100MHz... |
remus Occasional Visitor
Joined: Jun 23, 2004 Posts: 28 Location: Kent,England
Posted: Mon Nov 13, 2006 5:54 pm Post subject: |
From where the cable enters the receiver to where it is soldered to the jack plug is 63" |
Posted: Mon Nov 13, 2006 11:58 pm Post subject: |
remus wrote: | From where the cable enters the receiver to where it is soldered to the jack plug is 63" |
Thanks, that sounds a tad short to me. On another forum someone changed from an AA navigator to Garmin 660 and was disapointed in its TMC performance. He compared the antenna's, the AA's was 9ft long and the Garmin's around 7. He extended the Garmin by 2feet and it sprung in to life. I'll be looking in to extending ours tomorrow! |
Posted: Tue Nov 14, 2006 12:11 am Post subject: |
coastersteve wrote: | I'll be looking in to extending ours tomorrow! | If you find a supplier of the strange plug fitted to the end of the cable please let me know! - breaking into the device will invalidate any waranty etc, I appreciate the waranty is pointing out the obvious but you could damage the unit beyond repair (someone did just this on another TT forum recently, dislodging components off the PCB). Cutting the cable is not a good idea either as it contains more than one wire - Mike |
Andy_P Pocket GPS Moderator
Posted: Tue Nov 14, 2006 1:16 am Post subject: |
I think he attacked the unit with a hammer in the end. That probably invalidates the guarantee too!  |
