Pocket GPS World :: View topic - POI-SYNC Having no luck
steveky
PostPosted: Sat Jan 24, 2004 9:39 pm    Post subject: POI-SYNC Having no luck Reply with quote
Try as I might I cannot get the POI files to download to my Jornada(tomtom2) the blue bar gets about halfway but then I get "Could not create remote file" I've checked the FAQ and my proxy settings etc and they appear to be ok, is it something simple I am missing, I have copied some to my C drive and converted over to my PPC but then I cant get Tomtom to see them, I am getting to the point of desperation,anyone help?
Steve
PostPosted: Sun Jan 25, 2004 9:12 am    Post subject: Reply with quote
If you are running ActiveSync 3.7 or above, this may be the problem. These versions break connectivity between PC applications talking to the Pocket PC, and you might need to downgrade to a lower version of ActiveSync to resolve the issue.
steveky
PostPosted: Sun Jan 25, 2004 1:03 pm    Post subject: Reply with quote
Thanks Dave will give it a try, but how do I get TT to view the files I downloaded from my PC to the storage card where the maps are?
Steve
steveky
PostPosted: Sun Jan 25, 2004 1:27 pm    Post subject: Reply with quote
No still not doing it and can't reinstall Poi cos the web page won't come up Steve
PostPosted: Sun Jan 25, 2004 6:10 pm    Post subject: Reply with quote
Steve, If you can't access the webpage either for the POIEdit download, then it sounds like you may have a major issue on your PC, I can get to the download without any problems.
http://www.dnote.nl/pda/poi/PoiEdit/files/PoiEdit_v26.exe
I take it you do have POIEdit installed, and you are pointing the update wizard to http://www.pocketgpsworld.com/poisync/pocketgps.xml ?
All POIEdit is doing when installed is to download files from our website (which I presume is happening as you have connected and selected the POI's to download ?), then it saves them to your PC, and uses ActiveSync DLL's to copy the files to your Storage Card via the Active Sync connection.
Which version (and build release) of ActiveSync are you running ?
If you use POIEdit to connect and select a new POI to sync, when you click the next button after ticking the POI, what location do you get. You should get something like MOBILE://{full_dir_name}.
Please supply the full error that comes back and at what stage.
steveky
PostPosted: Sun Jan 25, 2004 7:15 pm    Post subject: Reply with quote
When I go to the link forPoi Edit v26.exe I get "This page cannot be displayed" and unfortunately I removed PoiEdit to try a new download but now I can't get to the page to reload it. I also removed activesync 3.7 and downloaded 3.5 s you advised previously but still it didn't work, I got as far as the blue download bar getting started but then it stopped and the message is "Could not create remote file" so I saved to C drive instead and that worked but then when I copied over to the PDA TT doesn't see the files on the storage card but they are in a sub directory of the map, should they be in the same directory as the map?
Steve
steveky
PostPosted: Sun Jan 25, 2004 7:40 pm    Post subject: Reply with quote
:D
Dave sussed the C drive bit of course they should be in the same directory (moment of madness) now just to solve the other bit, I will get PoiEdit back from recycle bin and try that. Steve
PostPosted: Sun Jan 25, 2004 10:05 pm    Post subject: Reply with quote
Which URL are you going to, to download POIEdit ? The one in my previous message works fine for me.
steveky
PostPosted: Mon Jan 26, 2004 12:16 am    Post subject: Reply with quote
Dave just tried the v26 linkagain but still doesn;t find the page so I took my original one from my recycle bin but still doesn't work to mobile so saving to c drive and copying over
Steve
PostPosted: Mon Jan 26, 2004 8:57 am    Post subject: Reply with quote
Ok, in that case then I would call your ISP because either you have major problems with your PC not authenticating DNS requests, or your ISP is blocking sites. Going to http://www.dnote.nl/pda/poi/PoiEdit/files/PoiEdit_v26.exe works fine. Seeing that you are also having problems using POIEdit that you had downloaded this suspects me that something is majorly corrupt on your IP stack on your PC.
steveky
PostPosted: Mon Jan 26, 2004 10:14 am    Post subject: Reply with quote
Dave the link works at work so it must be something to do with my isp as you say, thanks for all your assistance Steve Thumbs Up
hogbreath
PostPosted: Tue Mar 16, 2004 8:03 pm    Post subject: Reply with quote
steveky....had exactly the same problem as you but fixed it, you still interested ? You have to untick the automatically detect box in the LAN SETTINGS for both ISP, should work.
Pete Mr. Green
