shawsie Occasional Visitor
Posted: Wed Nov 08, 2006 4:02 am Post subject: TTN6 & iPaq |
Hi all, I've installed TTN6 ok except the sound/audio is no longer available on my iPaq 2490! If i do a hard reset the sound comes back to normal, but if i install TTN6 the sound dissapears with "error 0x37 opening wav driver". The pda functions fine, even TTN6, but no sound at all! it was all working fine before i had to hard-reset so I know it does work, but what am i doing wrong? Can anyone please help as I love TTN6, it's great. |
Posted: Wed Nov 08, 2006 7:07 am Post subject: |
After further installations I've found that if I say NO (Cancel) when TTN6 asks to do a reset, my sounds stays - yeah! I guess this is a workaround because as soon as I do a reset - for whatever reason - then my sound will dissapear (Hmph!).
Still.... Does anyone know how to add the audio driver back in WM5? |
djsleeps Occasional Visitor
Posted: Sun Dec 31, 2006 10:22 pm Post subject: |
Search your SDcard if that is where Tom Tom is installed, youy may also need to browse the windows directory, locate this file file BtCoreIf.dll and go into menu and delete this file reboot your pda and all should be well. |
leedslad1970 Occasional Visitor
Posted: Sat Feb 03, 2007 3:17 pm Post subject: |
djsleeps wrote: | Search your SDcard if that is where Tom Tom is installed, youy may also need to browse the windows directory, locate this file file BtCoreIf.dll and go into menu and delete this file reboot your pda and all should be well. |
I'm having exactly the same problem with the same conbination - however, I can't find the BtCoreIf.dll file!
Can you tell me where it would be hidden?
Paul |
Posted: Sat Feb 03, 2007 3:28 pm Post subject: |
OK - I have now found this file, but twhe I try to delete it, I get the error:
"Cannot delete 'BtCoreIf': There has been a sharing violation
The soursce or destination file may be in use"
Paul |
