Pocket GPS World :: View topic - Logging in to HOME
Logging in to HOME
deesoft
PostPosted: Sat Nov 04, 2006 12:52 am    Post subject: Logging in to HOME Reply with quote
Suddenly, when trying to download 6.52, I get the message telling me to Log In. What am I doing wrong. How do I log in. I succesfully downloaded 6.51 with no problems. I have Emailed TomTom and their suggestion is that I may have problems working through a Router. But surely there must be loads of people out there, working on Home Networks. I have even turned my FireWall off. But still with no success.
Has any one out there had the same problem??
I wait with baited breath!
Ipaq hx2750, TTN5, Globalsat 338 GPS, Garmin Nuvi 310D and GTM12, TomTom GO910 and now GO540
God gave us the Integer, the rest was devised by man.
Billlord
PostPosted: Sat Nov 04, 2006 1:30 am    Post subject: Re: Logging in to HOME Reply with quote
If you look at the bottom left of the home screen you will see a button that says login, this is what they mean. When you login first time you have to create an account.
simonvespa
PostPosted: Sat Nov 04, 2006 2:15 am    Post subject: Reply with quote
I am getting the same problem, and the same answer from TomTom. I have tried an trace on the sweet.tomtom.com server from three machines on differnet ISP's and it times out everytime.
I am not convinced of the router argument.
Simon
Oldboy
PostPosted: Sat Nov 04, 2006 9:28 am    Post subject: Reply with quote
If you look in Program Files/TomTom HOME there is a File called ServerError.txt
The first line of the Body Text will tell you what the error is.
Have a look at THIS and it might be of some help.
TT Via 135 App 12.075: Europe Map v1135
simonvespa
PostPosted: Sat Nov 04, 2006 1:15 pm    Post subject: Reply with quote
Had a look at the link and this is the error I am getting:
SERVER ERROR (Sat Nov 04 10:34:18 2006):
connection error
Request: ServiceDiscoveryRequest. Reply: ServiceDiscoveryReply
Server: "sweet.tomtom.com". Path: "/cens/sweet/sd/"
My Windows firewall is configured to allow TTH out. And I have had no problems with any other site or auto updater.
Running tracert from the command line on the sweet.tom.tom server shows the following:
Tracing route to sweet.tomtom.com [193.173.148.210]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms voyager.home
2 13 ms 13 ms 13 ms esr11.kingston5.broadband.bt.net [217.47.66.142]
3 13 ms 13 ms 12 ms 217.47.66.13
4 13 ms 13 ms 14 ms 217.41.217.1
5 14 ms 15 ms 13 ms 217.41.171.74
6 13 ms 13 ms 13 ms 217.41.171.50
7 13 ms 12 ms 13 ms 217.47.88.114
8 14 ms 14 ms 14 ms core1-pos6-1.kingston.ukcore.bt.net [62.6.40.74]
9 14 ms 14 ms 12 ms core1-pos7-3.ealing.ukcore.bt.net [62.6.201.38]
10 14 ms 14 ms 14 ms core1-pos1-0-0.telehouse.ukcore.bt.net [62.6.201
.82]
11 14 ms 14 ms 14 ms ldn-s2-rou-1002.UK.eurorings.net [195.66.224.54]
12 15 ms 14 ms 15 ms ldn-s2-rou-1022.UK.eurorings.net [134.222.231.22
5]
13 22 ms 23 ms 23 ms obl-rou-1021.NL.eurorings.net [134.222.231.173]
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * *
It then carries on timing out. So it looks like the connection problem is beyond the router(?)
Dont know if this helps. In the end I downloaded the upgrade from your site - worked great. Thank you :D
S
deesoft
PostPosted: Sat Nov 04, 2006 8:09 pm    Post subject: Upgrade Reply with quote
May I ask Simonvespa, what upgrade di you download, tah has solved thr problem.
Oldboy
PostPosted: Sat Nov 04, 2006 8:36 pm    Post subject: Re: Upgrade Reply with quote
He probably means the one on This Page.;)
deesoft
PostPosted: Sat Nov 04, 2006 10:13 pm    Post subject: 6.52 Upgrade Reply with quote
Thanks Oldboy!
910 Upgraded!! Why couldn't TomTom have sent me this solution when I was having problems?
David aka Deesoft Laughing
Oldboy
PostPosted: Sun Nov 05, 2006 12:21 am    Post subject: Re: 6.52 Upgrade Reply with quote
Ssshh.;)
22.094 (25 Sep 24)
