mixer25 Regular Visitor
Posted: Fri Jan 23, 2004 1:00 pm Post subject: Connecting PDA to Internet - Simple! |
Just to let you know it is very easy to connect Ipaq by bluetooth to mobile phone, you pair devices and simply connect to net.
The number I use is one from UK.net which is 0845 6091370 this number is great for testing connections etc, you need NO password or NO username, although I just put one in anyhow.
Just use it and DIAL and the rate is local to mobile phone tarrif.
As this is my work phone, I was wondering if there was a FREE way anyone knew of dialing up the net by o2? |
Dave Frequent Visitor
![](modules/Forums/images/avatars/92698813943397cac09a13.gif)
Posted: Fri Jan 23, 2004 2:08 pm Post subject: |
Most ISP's don't give out free numbers, Some will give out a regular local STD code or regional number to allow you to use it and have it deducted from your inclusive minutes, but you usually have to sign up for these and pay a monthly tarrif to them. |
DavidW Pocket GPS Moderator
Posted: Fri Jan 23, 2004 5:59 pm Post subject: |
None of the UK mobile networks allow free data calls to 0800 or similar freephone numbers. Orange used to - but removed the ability some time ago.
I believe the best bet for mobile Internet access in many cases is to use your mobile network's GPRS Internet APN, if it's available to you - though it does depend on your mobile tariff as to whether it is affordable.
I use Vodafone GPRS at 235 pence per MByte - it works out far cheaper when using it with the Pocket PC than paying 10p/minute peak (5p/minute off-peak) for dial-up. Apart from Orange's HSCSD service, which only works on some phones and costs more to use, dial-up Internet on GSM is only 9600bps. Vodafone GPRS with my Nokia 6310i can get to around 30000bps download.
David |
Talkingbollox Frequent Visitor
![](modules/Forums/images/avatars/1669536683418e9e94aaf72.gif)
Joined: 14/10/2002 15:11:34 Posts: 439 Location: United Kingdom
Posted: Fri Jan 23, 2004 6:32 pm Post subject: |
If you're on O2 you can have 100kbs free GPRS access every month on a business tariff. Anything in excess of that is charged at something like £3 a mb. |
