cloudchaser Occasional Visitor
Posted: Fri Nov 03, 2006 10:25 pm Post subject: Holux 236 GPS charger - mains & usb powered |
Hi all
I dont have my original charger handy and just have the car charger so wanted to get a mains or usb powered charger to use when indoors.
I prefer mains but will be fine with a usb powered cable too. Can someone please point out which would be a suitable charger? I am not sure which is the right one to use.
thanks in advance. |
Posted: Fri Nov 03, 2006 11:14 pm Post subject: |
I just plug my 236 units into the PC via a mini USB lead this is sufficiant to charge the units prior to use, although the PC tends to be on more than off - Mike |
eillo7 Regular Visitor
Posted: Fri Nov 03, 2006 11:51 pm Post subject: |
You can get USB chargers that plug into the mains, or into a 12V car socket. Output is 5V.
I use both varieties when travelling, instead of the standard Holux supplied car charger. This cuts down on the number of accessories I have to carry, as I have other devices that also use the USB 5V output to charge.
Standard USB to mini-USB cables are easy to come by... :D |
pcwinks Occasional Visitor
Posted: Mon Nov 13, 2006 7:27 pm Post subject: |
Does your 236slim work while being charged via car lighter socket with a non holux lead if it does what are using. |
Posted: Mon Nov 13, 2006 7:38 pm Post subject: |
Thanks guys - I found a mini USB cable that I did not know I had and am using that to charge. As I carry my laptop while travelling I dont need mains as such.
I also have the original car charger which works find. Dont have a non-Holux so can't help out on that one.
cheers |
