Pocket GPS World :: View topic - URGENT HELP - My TT1 wont turn on!
Agent_Trig
PostPosted: Fri Nov 03, 2006 5:16 pm    Post subject: URGENT HELP - My TT1 wont turn on! Reply with quote
Any help would be much appreciated.
I was using it only this morning and all was fine. Then I charged it up via USB and now I'm trying to turn it on but it will not turn on, I've kept the button down for over 5 seconds and it still wont turn on.
The little light does come on when I plug the USB cable into it.
I need it tonight to get to a hotel Sad
Any ideas?
thebinman
Banned
PostPosted: Fri Nov 03, 2006 5:29 pm    Post subject: Reply with quote
I guess you have the new V2 to be able to get the green light on when the USB lead is plugged in?
Have you tried (with USB connected) using a paperclip reset and removing/replacing the SD card?
Shinymera
PostPosted: Fri Nov 03, 2006 8:51 pm    Post subject: Reply with quote
I've seen mine do this also :x
I remove the SD card then connect to my pc or car and hit the reset. That brings it back.
Wonder if this is a problem with TT 1 V2's
bwg
PostPosted: Fri Nov 03, 2006 10:01 pm    Post subject: Reply with quote
My TT v1 did this and gave me the fright of my life as I really neede it. I pushed the reset button with a paperclip end then pressed the on button and it sprang to life. Smile
soweezy
PostPosted: Sat Nov 04, 2006 12:08 am    Post subject: Reply with quote
I get this too, with TT1 v2, but only after connecting it to the PC and using the Home program
using the reset fixes it but it's still a pain in the assets if you haven't got a pin handy
SW
Garmin Zumo 390LM
PostPosted: Sat Nov 04, 2006 9:08 am    Post subject: Reply with quote
soweezy wrote:
... but it's still a pain in the assets if you haven't got a pin handy
Taking the SD Card out and Re-inserting should achieve the same end.;)
soweezy
PostPosted: Sat Nov 04, 2006 1:14 pm    Post subject: Reply with quote
tried that after reading this post and it didn't work Confused
only a reset would let it boot up again
SW
Garmin Zumo 390LM
22.064 (26 Jun 24)
