Agent_Trig Occasional Visitor
Posted: Fri Nov 03, 2006 5:16 pm Post subject: URGENT HELP - My TT1 wont turn on! |
Any help would be much appreciated.
I was using it only this morning and all was fine. Then I charged it up via USB and now I'm trying to turn it on but it will not turn on, I've kept the button down for over 5 seconds and it still wont turn on.
The little light does come on when I plug the USB cable into it.
I need it tonight to get to a hotel
Any ideas?
Cheers |
thebinman Banned
Posted: Fri Nov 03, 2006 5:29 pm Post subject: |
I guess you have the new V2 to be able to get the green light on when the USB lead is plugged in?
Have you tried (with USB connected) using a paperclip reset and removing/replacing the SD card? |
Shinymera Regular Visitor
Posted: Fri Nov 03, 2006 8:51 pm Post subject: |
I've seen mine do this also :x
I remove the SD card then connect to my pc or car and hit the reset. That brings it back.
Wonder if this is a problem with TT 1 V2's |
bwg Occasional Visitor
Posted: Fri Nov 03, 2006 10:01 pm Post subject: |
My TT v1 did this and gave me the fright of my life as I really neede it. I pushed the reset button with a paperclip end then pressed the on button and it sprang to life. |
soweezy Pocket GPS Verifier
Posted: Sat Nov 04, 2006 12:08 am Post subject: |
I get this too, with TT1 v2, but only after connecting it to the PC and using the Home program
using the reset fixes it but it's still a pain in the assets if you haven't got a pin handy _________________ SW
Garmin Zumo 390LM |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Sat Nov 04, 2006 9:08 am Post subject: |
soweezy wrote: | ... but it's still a pain in the assets if you haven't got a pin handy | Taking the SD Card out and Re-inserting should achieve the same end.;) _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
Posted: Sat Nov 04, 2006 1:14 pm Post subject: |
Oldboy wrote: | soweezy wrote: | ... but it's still a pain in the assets if you haven't got a pin handy | Taking the SD Card out and Re-inserting should achieve the same end.;) |
tried that after reading this post and it didn't work
only a reset would let it boot up again _________________ SW
Garmin Zumo 390LM |
