Pocket GPS World :: View topic - Can TT5 be installed on SD card?
jonmat
PostPosted: Wed Nov 01, 2006 10:40 am    Post subject: Can TT5 be installed on SD card? Reply with quote
I'm sure this has been asked before but....
Is there a way to install TT5 on the SD card so that in the event of my Ipaq needing a hard reset for example, I can then run TT5 straight from the SD card?
Thanks.
View user's profile Send private message Yahoo Messenger MSN Messenger
Green_ninja
PostPosted: Wed Nov 01, 2006 12:25 pm    Post subject: Reply with quote
As I understand it although you can install all the maps POI's etc to the SD/CF card TT requires it's basic files to be in the PDA memory. So no.
jonmat
PostPosted: Wed Nov 01, 2006 2:44 pm    Post subject: Reply with quote
Any suggestions/advice how to recover TT from the SD card if Ipaq problems. If I'm out on the road and TT goes down would be great to be able to get it up and running.
Border_Collie
PostPosted: Wed Nov 01, 2006 4:49 pm    Post subject: Reply with quote
The following works on my Mio P350 and as you are using TT I assume it will be the same.
Open the backup of your SD Card on your Desktop and add a new folder, I've named mine New Folder (original eh?).
If you never saved a copy of TTN5.21 update, download and save it now before going any further.
Now look for the TTN.CAB in the saved navupd521 update folder, it's in the Pocket PC folder, and copy and paste to the New Folder. On your CD's look for GPS.CAB, PIMAddIn.CAB, and a voice .cab. e.g Jane is engf.cab. Copy and paste these files into the New Folder.
Now right click on one, choose properties and tick the box to make it Read Only. Do this with each of the files. (If you don't do this the files will vanish into thin air after being used and you won't be able to use them again without going through the above proceedure).
You can now copy and paste the New Folder to your SD Card.
In the event of a battery failure, plug in car charger or mains adapter.
Switch on and go to Start - Programs - File Explorer.
Second line from the top, it will probably say My Documents, tap to the right of the Mobile icon and select Storage Card. Now tap on New Folder where you will see the cab files.
Tap on each cab file, one at a time, and install each one.
Everything will now be running as normal except you will have to re-setup your Speed Camera warnings/distances.
oddsock
PostPosted: Wed Nov 01, 2006 8:16 pm    Post subject: Re: Can TT5 be installed on SD card? Reply with quote
Thanks.
Two words!! .. "SPRITE BACKUP" it will restore every thing lost from the volatile memory.
TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest
Border_Collie
PostPosted: Wed Nov 01, 2006 11:29 pm    Post subject: Reply with quote
Yes, the programme has good reports but is it really worth paying for when you may never use it?
Doing it the way I prefer may take slightly longer than using Sprite, in the event of a flat battery, but as I'm a tight wad, no Sprite for me. :P
freemans
PostPosted: Thu Nov 02, 2006 2:37 am    Post subject: Reply with quote
I use Sprite Backup for my device and it did save me several times especially when you really got lost:)
jonmat
PostPosted: Thu Nov 02, 2006 6:19 pm    Post subject: Reply with quote
Great, sounds good. Will copy all the files and see what happens the next time TT will not work.
deepeejay
PostPosted: Mon Nov 06, 2006 10:53 pm    Post subject: Use a good backup Reply with quote
I use SPB Backup
Dave J
In sunny Extremadura
Trevor1234
PostPosted: Wed Nov 08, 2006 6:05 pm    Post subject: Reply with quote
Hi jonmat
A Backup programme is the most important thing one can have on their PDA. I have Sprite (there are others that supposed to be as good) and believe me when I say that it’s a blessing from God.
Flat battery? Hard Reset? Everything gone and you are stuck in France and about to enter Paris? no problem for Sprite. In two minutes all will be restored, Bluetooth settings, Wifi settings, and all programmes and away you go.
I wouldn’t be without it.
Tomtom Go 720.
Navcore 9.510
GPS World Traffic cameras
Home 2.7
iPhone 3G
Rybren
PostPosted: Wed Nov 08, 2006 7:26 pm    Post subject: Reply with quote
I've used the PPC2003SE built-in backup software to back everything up to an SD card. Using the restore function, I have successfully restored TT5 to my PPC following a hard reset and have been up and running again in no time.
The built-in software may not be as good as Sprite or some of the other packages out there, but it gets the job done for me.
Trevor1234
PostPosted: Wed Nov 08, 2006 10:24 pm    Post subject: Reply with quote
Hi Rybren
Fair enough, we both use a Backup programme. And the fact is that as long as one backs up the PDA one cant go wrong. Yes, backup, it’s of the utmost importance.
One should never land up in the embarrassing position (like jonmat) and have to reinstall Tomtom when arriving back home. By then ones holiday may have been ruined.
Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G
Rybren
PostPosted: Thu Nov 09, 2006 8:34 pm    Post subject: Reply with quote
Trevor
Agreed. Backups are essential.
Just curious, do you know if Sprite will backup things that the built-in software misses? I'm assuming that the built-in misses something, what, I don't know.
Trevor1234
PostPosted: Thu Nov 09, 2006 11:35 pm    Post subject: Reply with quote
Hi Rybren
When I purchased my first PDA and TT3 I used the Backup programme already installed on my Ipaq. As a test run I done a Hard reset, tried to restore and everything failed dismally. It was that episode that made me splash out a few quid and buy a proper backup programme. And as I have said before, it backs up everything and restores everything.
Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G
22.062 (12 Jun 24)
