Courior Occasional Visitor
Posted: Fri Oct 13, 2006 1:50 pm Post subject: Maps from 269+ onto my c710??? |
I had a Mio 269+ which had slovakia and hungary among other eastern european countries. I now have a C710. Can i take the maps from the 269+ DVD and stick them on my C710?
Thanks in advance!! |
lbendlin Pocket GPS Staff
![](http://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Sat Oct 14, 2006 4:21 am Post subject: |
Technically yes. But why do you want to go through the Navigon pain when you can have the much better iGO? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sat Oct 14, 2006 3:55 pm Post subject: |
I dont understand what you mean about the navigon.. my old navigator was also a Mio. did they run different softwares (except for the obvious version number difference). Thanks for the help! |
Posted: Sat Oct 14, 2006 7:06 pm Post subject: |
The older Mios run MioMap v2 ( Navigon ). The newer run MioMap v3 (iGO). _________________ Lutz
Posted: Sat Oct 14, 2006 11:40 pm Post subject: |
Ah i see. good to know that.. ok, i have the iGO dvd, with the eastern european maps on it. I have blue toothed the map file into the relevant directory on my C710 and it says that its locked. how do i go about unlocking it? its just 2 maps that i want. |
Posted: Sun Oct 15, 2006 1:46 am Post subject: |
maps are locked to the SD card. You have to put the SD card into the 710, not copy the maps to the 710. _________________ Lutz
Posted: Sun Oct 15, 2006 9:10 pm Post subject: |
I have tried creating a Maps folder on an SD card and putting them in there but to no avail. so far i have downloaded the IGO dvd and have copied the 2 map files i want to my C710 (didnt work) and then deleted them and put them on sd card (didnt work).. any advice on what to do would be so much appriecated!! Thanks in advance!! |
CompufixUK Occasional Visitor
Posted: Sun Oct 22, 2006 1:03 am Post subject: |
The maps from V2 (.map extension) and the ones from V3 (.fbl extension) are incompatible, unless you wish to dig into them and alter them somewhat. Thats primarily why they wont work. Try altering the file extension of the V2 maps and watch the result |
Morkin Occasional Visitor
![](modules/Forums/images/avatars/146034973045b49d0ed6229.jpg)
Joined: Oct 24, 2006 Posts: 31 Location: The Netherlands
Posted: Tue Oct 24, 2006 11:45 pm Post subject: |
Courior, you cannot just copy the maps to your sd-card or your flash disc.
The maps are locked because you don't have the correct license.db on your Mio.
I am guessing that you have Western Europe on your Mio.
So you have a lincense.db for Western Europe only. _________________ Mio C710 unlocked.
Miomap deleted. - iGo with Western Europe on Flash disk.
Website: http://mio.digiwalker.googlepages.com/ |
Posted: Wed Oct 25, 2006 6:55 pm Post subject: |
Thanks, that has been most helpful. Can i copy the licence over from the igo software and then it will work? as the igo software has the same maps that the c710 has plus more.
Thanks |
Posted: Wed Oct 25, 2006 7:54 pm Post subject: |
you can use iGO SD cards in the 710. You cannot copy the contents of the SD card over to the flash though. (You can copy it but it won't work) _________________ Lutz
