Pocket GPS World :: View topic - Nuvi 310 Deluxe and POI displays
bunch92
PostPosted: Wed Oct 25, 2006 3:17 pm    Post subject: Nuvi 310 Deluxe and POI displays Reply with quote
I have a Nuvi 310 Deluxe and I couldn't find the answer to the following question on the forum:
- I loaded (using POI Loader) several POIs (in 1 go, all together). These POIs were speed cameras and shops (such as Tesco, Sainsbury, etc ...)
When I drive past a speed camera at high speed, I get the warning + the little camera icon on my nuvi screen. But when I drive past a Tesco/Sainsbury/etc.. , I DO NOT see anything on the screen. I set the alarm on for both customs POI and speed cameras.
If I do a POI search using the menus, all my Tescos/Sainsburys/etc .. can be found and I can create a route to them.
Now the "funny" thing. If I set these Tesco/Sainsburys/etc.. as favourite locations, they DO display on map !! huh ?
Anyone else has this problem ?
Thank you.
swing
PostPosted: Wed Oct 25, 2006 4:35 pm    Post subject: Reply with quote
That all sounds like it's working correctly to me - if you want alerts for the non speed cameras you will need to use POI Loader in manual mode and setup each alert individually (I think, I've never done that).
bunch92
PostPosted: Wed Oct 25, 2006 4:51 pm    Post subject: Reply with quote
Oh I see. I used the automatic mode indeed. I will try the manual mode tonight and set an alert when within 500 meters.
I will let you know if it works. Thanks
bunch92
PostPosted: Thu Oct 26, 2006 10:12 am    Post subject: Reply with quote
Well , it sort of worked. On my way to work, I drove past something like 30 custom POIs, but the nuvi 310D only managed to get an alert for 1 tesco (with icon on map) and 1 Holiday Inn (without icon on map).
I set the alert to every POIs within 1000 meters (0.6 miles) so I should have had many more .... Sad
Anyone else had that problem ?
