Pocket GPS World :: View topic - mio p550 battery replacement
lofric
PostPosted: Sat Oct 07, 2006 1:19 pm    Post subject: mio p550 battery replacement Reply with quote
has anyone done this yet
i have just purchased a new 1700mAh replacement and have had a peak inside the p550 to see how hard it is to change.
it looks harder than i thought as the connector doesn't look to easy to get at,
it almost looks like the rest of the back of the unit has to come off, which i'm reluctant to do. of course when the new battery arrives it might all become clear as i can get a look at the new connector.
any help gratefully received !!!
doogy
PostPosted: Wed Oct 11, 2006 5:58 pm    Post subject: Reply with quote
Hi lofric,
Have been thinking of doing this myself but been waiting on someone reporting how easy it is and how much better the hi-cap battery is. Sorry I can't be of any assistance but would really appreciate if you were to post your findings back here.
Good luck!
Pc-Mobile
PostPosted: Thu Oct 12, 2006 7:59 am    Post subject: Reply with quote
Why do you have to replace the battery?
It cannot be more than 2-3 months old?
Pc-Mobile
http://pc-mobile.net/gps.htm
lofric
will do.
still waiting for delivery of new battery.
lofric
PostPosted: Thu Oct 12, 2006 8:06 am    Post subject: Reply with quote
i'm a serial fiddle'r (SP). i have to play with the things i buy, make them better, have them apart etc.
also the originals only 1250mAh and it does'nt seem to last very long at all.
i use my pda with memory map while out in the countryside. i do use a battery extender and they work really well.
lofric
PostPosted: Mon Oct 23, 2006 8:01 pm    Post subject: Reply with quote
ok it wasn't as hard as i thought it would be, the biggest problem was getting the old battery out. mitac stick it in with double sided tape. jesus it was
sticky, it sounded like the pda was going to break! i stupidly levered it up with a screwdriver and marked the case.( there goes my warranty ).
the connector was easy to remove and the new battery went in a dream.
was it worth it ? not sure really, the new 1700mAh battery definately lasts longer but not a hell of a lot. tom tom does kill the battery though & i haven't
tried it with memory map yet. i haven't had to recharge it as often which is a good thing.
would i do i again? probably because thats the way i am. but if you're a bit squeemish about breaking things i'd think twice or at least wait until your old batterys had its day, at least then you'll have no choice. if they wern't stuck down it would be an absolute piece of cake.
Border_Collie
PostPosted: Mon Oct 23, 2006 8:57 pm    Post subject: Reply with quote
Maybe several minutes with a hairdryer blowing gently on it would have helped a bit.
Border_Collie
lofric
PostPosted: Mon Oct 23, 2006 9:16 pm    Post subject: Reply with quote
maybe, but its well hidden under the battery, & i dont think iv'e come across sticky tape quite so strong!, i reckon it would hold a car battery in place.
Border_Collie
PostPosted: Mon Oct 23, 2006 10:07 pm    Post subject: Reply with quote
What about
Heat Gun, 250 - 1,100 F
Features Strips paint and varnish, thaws frozen metal pipes, loosens tile and putty, remelts adhesives and more Variable temperature control (250 - 1,100F) for a wide variety of applications 2-speed blower setting (8 or 14 cfm) Thermocouple control maintains precise temperature Ceramic core protects the heating element for longer tool life Standard Equipment Tool Only Specifications Air temperature 250 - 1,100F Air volume 8 and 14 cfm AMPS (120V) 12.5 Watts (AC only) 1,500 Overall length 10" Net weight 1.3 lbs. Shipping weight 1.5 lbs.
:P :D :P
PostPosted: Mon Oct 23, 2006 10:32 pm    Post subject: Reply with quote
Joking aside, using a heat gun to do this will probably do irreparable damage to the device, for a start the screen doesn't like high temperatures and some heat will get through to the front.
Heating up a modern LiPo type battery is also not a good idea, if it decides to let go you will loose the kitchen table as well as the PDA.
I appreciate the Joker but there are some that might read this and actually try it Wink - if nothing else the case probably wont re-fit the device once you have melted it! - Mike
Border_Collie
PostPosted: Mon Oct 23, 2006 10:39 pm    Post subject: Reply with quote
I never thought of that Mike. Can you somehow delete my remarks?
Pc-Mobile
PostPosted: Tue Oct 24, 2006 8:48 am    Post subject: Reply with quote
The excercise in order to make it last longer (not that much) is not worth it IMO. After all it does not really matter even if the battery is worn out if all you use is for navigation in car.
Pc-Mobile
lofric
PostPosted: Tue Oct 24, 2006 6:21 pm    Post subject: Reply with quote
agreed pc-mobile. now if they came up with a 2500mAh battery that would be a different matter.
i have now had a chance to use it with memory map and it lasted at least an hour longer before the battery warning came up. this was my princible reason for changing the battery.
PostPosted: Tue Oct 24, 2006 6:41 pm    Post subject: Reply with quote
One other idea for longer battery duration is to use an external charger pack, THESE devices pack quite a bit of power 3600mAh, but they are quite light, there is a newer (larger) capacity pack due out soon that allows you to have 5400mAh available, but I am not too sure about the weight.
The 3600 unit is great for charging anything from the PDA, GPS etc. Mike
23.052 (14 May 25)
