EGC Occasional Visitor
Posted: Fri Oct 20, 2006 12:42 pm Post subject: TT6 different Euro maps |
Currently using TT5.21 but considering the upgrade to TT6.
I understand from a friend of mine (who is more market-aware than I am) that there are two European maps available for TT6 - v650 (TeleAtlas?) and v652 (NavTech?). Can anyone confirm this? Which is likely to be the best map to use? |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Fri Oct 20, 2006 6:55 pm Post subject: |
I'm not sure tht the NAVTEQ map is available for the PDA or Mobile versions. It is the standard map on the RIDER and ONE v3 European version, both of which are PNDs. I'm not sure if the NT map can be used on the GOs, either. _________________ Tim |
xbyt Occasional Visitor
Posted: Mon Oct 23, 2006 4:49 pm Post subject: |
The navteq map is compatible with tt navigator v6. |
MarkHewitt Frequent Visitor
Joined: Nov 16, 2004 Posts: 1077 Location: Chester-le-Street & York
Posted: Tue Oct 24, 2006 9:46 am Post subject: |
xbyt wrote: | The navteq map is compatible with tt navigator v6. |
But as I understand it, not sold seperately. |
Posted: Tue Oct 24, 2006 11:31 am Post subject: |
MarkHewitt wrote: | xbyt wrote: | The navteq map is compatible with tt navigator v6. |
Yes, you're right.
The map is only supplied with TT GO, but is compatible with TT Navigator. |
TuurG Frequent Visitor
Joined: Nov 23, 2004 Posts: 454 Location: Haarlem, The Netherlands
Posted: Tue Oct 24, 2006 10:37 pm Post subject: |
I think that friend of yours is not so market-aware. Navteq maps are not compatible with TT Navigator 6 (PocketPC), only with Rider and One NE.
Also, both map versions v6.50 and v6.52 exist as TeleAtlas maps.
The Navteq map on the One NE is also v6.52. So the version number is not conclusive for the provider.
If you want to be sure about the provider, check the About box, and check for details. You will see wich provider is mentioned in the copyrights. _________________ GO1005
MGC GT 1968
MGB Cabrio 1973 |
Posted: Tue Oct 24, 2006 10:41 pm Post subject: |
TuurG wrote: | Also, both map versions v6.50 and v6.52 exist as TeleAtlas maps.
TTN6 is shipped with (TeleAtlas) maps v6.52 _________________ GO1005
MGC GT 1968
MGB Cabrio 1973 |
Posted: Wed Oct 25, 2006 10:56 pm Post subject: |
TuurG wrote: | I think that friend of yours is not so market-aware. Navteq maps are not compatible with TT Navigator 6 (PocketPC), only with Rider and One NE.
If you want to be sure about the provider, check the About box, and check for details. You will see wich provider is mentioned in the copyrights. |
Are you really sure that the Rider and One Maps are not compatible with Navigator?
Mine is working, perhaps I'm running either Rider or One in my HP PocketPC! |
