freebie Occasional Visitor
Posted: Sun Oct 22, 2006 1:07 pm Post subject: TT Nav 6 lost postcodes |
Running TTN6 on 2210
When first loaded and on reloads all ok, but have found after a couple of trips I lose the 6/7 Postcode option, all the files seem to be OK, If i delete and re-load TTN6 works ok the stops again. Never had the problem with TTN5.
Any Ideas
Cheers |
Oldboy Pocket GPS Moderator
Posted: Sun Oct 22, 2006 4:27 pm Post subject: |
Do you mean that when you go to Navigate to ... | Address | Postcode, the Icon is greyed out?
Or are you talking about something else?
Please tell us what happens, and then we'll understand.;) _________________ Richard
Posted: Sun Oct 22, 2006 6:46 pm Post subject: |
No the icon is there when select it only offers 4 digit postcode |
Posted: Sun Oct 22, 2006 9:14 pm Post subject: |
Is there a Folder named 'Zip' in the Root of the Storage Card?
Has it got a File named 'Great_Britain-Postal' in it?
I'm not sure if TTN6 requires you to have an empty Folder called Tomtom in the Root of the Card also. _________________ Richard
Posted: Sun Oct 22, 2006 9:34 pm Post subject: |
Hi Yes there is a zip folder in root of card and it contains file, I have created a folder called tomtom in root (found info on another post) still not working. |
Posted: Sun Oct 22, 2006 10:29 pm Post subject: |
Is the File about 9.8MB?
What is the name of the File? _________________ Richard
Posted: Mon Oct 23, 2006 8:47 am Post subject: |
The file is 8.41M ! called Great_Britian
when I explore the my docs file I found another zip folder containing 9.6M file called great_britain |
Posted: Mon Oct 23, 2006 9:41 am Post subject: |
I think i've sorted the problem,
copied the zip file from SD 8.41 M, card to my CF card (just to store)copied zip file 9.6M from my documents into SD card deleted zip file in my documents folder. Restared TTN6 all seams to be OK.
Will let you know if it keeps working
Thanks for your help, wouldn't have noticed both files or size if you hadn't asked |
