Pocket GPS World :: View topic - Converting path/track to route on Garmin
bsyyy
PostPosted: Sun Oct 22, 2006 7:56 am    Post subject: Converting path/track to route on Garmin Reply with quote
I've been using Google Earth to record paths (tracks) and then converting them to Garmin files for use on my 60C. Does anyone know of a way I can convert these paths to Garmin routes instead? Or, is there a way to convert tracks to routes on the Garmin?
Brett
missing_user
PostPosted: Sun Oct 22, 2006 2:06 pm    Post subject: Reply with quote
Garmin MapSource has these possiblities.
You need a PC/Laptop, Free updated MapSource software, CitySelect/CityNavigator/MetroGide.
Any track from my 'units' can be downloaded to the PC, converted to a route and depending on the unit loaded onto the unit.
All tracks and routes are available to view from Mapsource direct onto Google Earth
bsyyy
PostPosted: Sun Oct 22, 2006 8:04 pm    Post subject: Reply with quote
Thanks Strumble but how do I convert a "track" to a "route"?
cheers
Brett
missing_user
PostPosted: Sun Oct 22, 2006 8:51 pm    Post subject: Reply with quote
Open Mapsource.
Load the track you have saved.
Use the MapSource 'Route Tool' and click on the first track point on the map view.
Then click on the subsequent track points [perhaps 1 in 20 of the points] but specifically where an option [direction change] may occur!
Each time you click on a track point the pink/purple route line is extended!
You can select parts of a track and make several different routes!
Getting the route into the unit is dependent on the model, but in my case it is so easy to transfer to the 60CSx.
Any help??
Having tracks from around Ireland from my Summer Holiday, I have created routes [eliminating detours and pedestrian viewing] to save for a future return to the area!!
All these tracks and routes are available to view in Google Earth direct from MapSource.
bsyyy
PostPosted: Mon Oct 23, 2006 6:56 am    Post subject: Reply with quote
Thanks Strumble. That is the only way I see it can be done. Unfortunately my tracks are thousands of kms long and I don't want to spend days overlaying a route. I figure there must be a simple way to rewrite a track code, or convert the file.
cheers
Brett
missing_user
PostPosted: Mon Oct 23, 2006 10:19 am    Post subject: Reply with quote
Just taken 5 minutes to create a route from a track from a campsite in Switzerland to the French Port of Calais with an overnight stop![960km]
If you are following a major road then the 'Route tool' is only selecting the track points at directional changes [could be 300km between] or at your forced toilet or fuel stops!
My idea of 1 in 20 selection of track points was for complicated routes in cities or as a pedestrian, you did not mention 'thousands of kms long' which make it easier/quicker, not more complicated!
Oldie
PostPosted: Mon Oct 23, 2006 11:32 am    Post subject: Reply with quote
cheers
Brett
Have a look at my POIConverter program ( version 3.18 ) http://rjdavies.users.btopenworld.com/html/poiconverter.html it will convert track data to route data.
1. Run the program Smile
2. Use the Option menu to set the Track Filter to 10
3. Click on the [Track data] button
4. Open a file containing Track data, eg track.gpx
5. Click on the [Route data] button
6. Save the route data to a file, eg route.gpx
7. Repeat steps 3 to 6 or Exit
Edited to fix link.
Various TomToms, Garmin eTrex Legend, GPSMAP 60CSx, Oregon 550t, Forerunner 405
missing_user
PostPosted: Mon Oct 23, 2006 12:46 pm    Post subject: Reply with quote
Thank you
The link to the download is not working.
Oldie
PostPosted: Mon Oct 23, 2006 12:55 pm    Post subject: Reply with quote
strumble wrote:
Thank you
Should be OK now Smile
missing_user
PostPosted: Mon Oct 23, 2006 1:04 pm    Post subject: Reply with quote
Oldie wrote:
strumble wrote:
Thank you
The actual download link from your website is not working!
Oldie
PostPosted: Mon Oct 23, 2006 2:58 pm    Post subject: Reply with quote
Sorry about that Embarassed For some reason the file was not transferred to the website. It looks as though I had exceeded my disk quota on the server although it did not report an error.
missing_user
PostPosted: Mon Oct 23, 2006 3:22 pm    Post subject: Reply with quote
Thank you.
All is working now.
22.064 (26 Jun 24)
