paul_pompey Occasional Visitor
Posted: Sun Oct 22, 2006 2:57 am Post subject: POI slowing things down |
I have just intalled many poi's from poi edit but now my tomtom navigator 6 runs real slow on my pda
any ideas as to what the problem is ?
thanks |
xda Lifetime Member
Posted: Sun Oct 22, 2006 5:02 am Post subject: |
If you filled in your profile so we knew what PDA you are using then we could help you. The most likely problem is that you have too many POI's displayed or your PDA's processor is slow. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
xda Lifetime Member
Posted: Sun Oct 22, 2006 5:04 am Post subject: |
If you filled in your profile so we knew what PDA you are using then we could help you. The most likely problem is that you have too many POI's displayed or your PDA's processor is slow. Either way removing some of the POI's will improve things. _________________ Graham.
Oldboy Pocket GPS Moderator
Posted: Sun Oct 22, 2006 8:41 am Post subject: Re: POI slowing things down |
paul_pompey wrote: | any ideas as to what the problem is ? | It is usually caused by Enabling too many POI's.
If you need to be aware of the POI use Warn When Near instead.;) _________________ Richard
FrequentFlyer Lifetime Member
Posted: Sun Oct 22, 2006 9:07 am Post subject: |
Does this generally apply to all sat nav systems ? |
Posted: Sun Oct 22, 2006 11:38 am Post subject: |
It seems to be mainly PDA's. _________________ Richard
Posted: Sun Oct 22, 2006 3:08 pm Post subject: |
thankyou for your help sorry i was sparse on the information !
I have a mitac mio 168 which was running fine but as soon as i installed all the poi's it run so slow as to be unuseable.
Yes i have tried disabling the poi's and yes it runs fine again I was just unaware that having them enabled even when they not showing on screen would slow things down.
So if i have them disabled does that mean i wouldnt be able to navigate to a poi ? |
xda Lifetime Member
Posted: Sun Oct 22, 2006 3:57 pm Post subject: |
One thing you can do is, if you have any POI files such as Tesco etc. that cover the whole country is to edit the POI file and remove all the locations you are not likely to use. _________________ Graham.
Posted: Sun Oct 22, 2006 4:41 pm Post subject: |
paul_pompey wrote: | So if i have them disabled does that mean i wouldnt be able to navigate to a poi ? | You will be able to Navigate to any Location in any of the POI Files you have.
But be aware that this could then Enable that POI again. This shouldn't be too much of a problem if only 1 or 2 are Enabled. _________________ Richard
