Glassman1 Occasional Visitor
Posted: Sat Jan 17, 2004 7:10 pm Post subject: DIRECTION INDICATOR GONE. |
Hi all,
Brand new today to this forum so hi to all. I have had my ipaq 3870 with tomtom gps v.2.08 for 4 months now and has been spot on up untill recently. When i now load data in for a route it calculates everything fine but now it does not show the actual route you are going along ie: the thick red outline on the road to which you follow and the green arrows that come up when telling you were to turn.
I have been all through various settings in software and today i have uninstalled the whole tomtom software and gps then re-installed a few times but still does not show the direction indicator( the thick red outline on road) i havr even updated to gps V.2.09 in the hope that this would help but to no avail. So i really would appreciate any help from you guys and hope there is an answer out there as i am at the end of my tether. Any help much appreciated. |
johnmar Regular Visitor
Joined: 21/02/2003 11:37:04 Posts: 164 Location: United Kingdom
Posted: Sat Jan 17, 2004 7:57 pm Post subject: |
I believe you need to make the following change in Properties:
File>Properties>Advanced>Route :"Dashed in Foreground".
From experience, I have found that this preference changes to "Hidden" following a lock-up or crash. Usually it also means that other preferences or Favourites are also lost. You can safeguard against this by saving copies of the two TomTom settings files in My Documents>Tom Tom Navigator Settings as backups in another location. When necessary these can be used to overwrite the default settings.
Good luck _________________ John
iPAQ3830 (32MB) PPC2002 ROM 1.20
CF Expansion Pack
Holux GR-213 GPS Mouse (GSW3.1.1 -3.1.00.07 C23B1.00)
Kingston Elite Pro 1 GB CF Card for maps
Viking 512MB SD Card (not used for navigating)
TTNav 5.210 (5430) Maps of W Europe |
Posted: Sat Jan 17, 2004 8:53 pm Post subject: |
:D Hi johnmar,
Thanks for theprompt reply m8 you dont know how much this is appreciated been pulling hair out. Anyway many thanks and u say this is has been caused when it has crashed at some stage. And bt saving which files to another location can i restore my original defaults?
Many thanks.. |
DavidW Pocket GPS Moderator
Posted: Mon Jan 19, 2004 1:34 am Post subject: |
Recent versions of TomTom Navigator 2 (I think version 2.22 and onwards - though I expect almost everyone will have upgraded to 2.24 by now) put the settings files in a folder called "TomTom Navigator Settings" inside "My Documents". If you're not already using version 2.24, I suggest you get the upgrade from the TomTom web site (click support, it should be downloadable from one of the top few answers).
There's one file in that folder for global settings, and one for each map segment you use (the latter contains information such as your favourites).
You can back these files up and restore them. An alternative, if you believe them to be causing you problems, is to delete them. If the files are missing, TomTom Navigator 2 will rebuild them with the default settings when you next start the program.
David |
Posted: Mon Jan 19, 2004 7:27 pm Post subject: |
Thanks Davew for the info will do aas u say however i did do what the previous post said and change hidden files to dashed in background, this did cure it but i have also upgraded and everything seems fine apart from i cannott record poi by using my calendar button. Have gone through tutorial word for word but when i launch checkpoint now and then try to record a poi i just get my calendar up, any help on this davew would be most appreciated many thanks again m8.. |
Darren Frequent Visitor
Posted: Mon Jan 19, 2004 7:51 pm Post subject: |
Assuming you have configured CheckPOInt to use the correct hardware button for POI recording then from experience I have found that a soft reset is sometimes required before the setting takes effect. You'll also not see this working unless you have a position fix. _________________ Darren Griffin |
Posted: Mon Jan 19, 2004 7:59 pm Post subject: |
Hi Darren understand the bit on soft reset nad have tried this but to no avail. Can u please explain the fixed position m8, sorry but pretty new to all of this and i am willing to learn, many thanks m8... |
Posted: Mon Jan 19, 2004 8:03 pm Post subject: |
No need to apologise, we've all been there! What I meant is that you need to get a satellite fix etc before the record POI function will work, you can't test it sat on the sofa indoors.
Take it out for a spin, get a location fix so that TomTom is functioning and then test the recording facility _________________ Darren Griffin |
Posted: Mon Jan 19, 2004 8:06 pm Post subject: |
Thanks for the prompt reply m8 and i thought that this was the case and i was out in vehicle @ 12.30am last night but still no joy all i keep getting is calendar. However i migh add that i have just been into settings and buttons and when i look @ my designated button which was set as calendar i have a few options in here and one being checkpoint to which i thought this is it however all this does is to launch the application. Would you know what this should be set too m8 thanks |
Posted: Mon Jan 19, 2004 8:12 pm Post subject: |
The buttons option in settings allows you to configure a button to launch an application. This is different to the setting within CheckPOInt where you configure a hardware button for POI recording. To avoid confusion allocate a different button i.e. Launch CheckPOInt using button 1 (also configure CheckPOInt to launch TTNav automatically and exit CheckPOInt when TTNav is exited). This way pressing button 1 will launch TTNav with CheckPOInt running and exiting TTnav from its menu will close CheckPOInt as well.
Then within CheckPOInt set the hardware POI button to Button 3. Soft reset, go for a drive and see if this has reolsved the problem? _________________ Darren Griffin |
Posted: Mon Jan 19, 2004 8:20 pm Post subject: |
Cheers m8 will take your advice now and go for a ride.. |
Posted: Mon Jan 19, 2004 10:59 pm Post subject: |
:D Cheers m8 just done exactly what u say and works a treat many thanks once again.
Cheers Glassman1 |
sparkster Occasional Visitor
Joined: Jan 16, 2004 Posts: 14 Location: Wolverhampton , England
Posted: Tue Jan 20, 2004 2:12 am Post subject: |
Nice instructions darren, this thread also answered my question as well,,, i was getting the same thing,, all sorted now,, thanks m8 |
Posted: Tue Jan 20, 2004 8:28 am Post subject: |
Glad to hear it resolved your issues _________________ Darren Griffin |
